newbie exhaust question
Discussion in 'Introduce Yourself' started by 1ll-WRX, Oct 22, 2006.
  1. 1ll-WRX
    So i just picked up a JIC Magic Ti axleback and it looks like the flange section that meets up to the resonator part tapers to 2.5in....I currently have a full 3in catback from Random tech...so I'm not gonna be able to switch out axleback peices correct?
  2. pEd
    you can always get a 3" flange welded on.
  3. 1ll-WRX
    do you think thatd be pricey?
  4. calmnothing
    around $75-100....more if you want stainless steel.....also MIGHT have to provide flange....mainstream might can do it and have the flange
  5. crashtke
    Wow I had an entire dual exhaust system with an h pipe made for my 63 nova for $120...given it was not stainless, but just to weld a flange....$75-$100?
  6. calmnothing
    Well I was using a shop. Where'd you get something like that so cheap?
  7. Alex
    You could just mate them up and see if they fit regardless. Odds are the flanges will still mate, you'll just have the 3" to 2.5" at the axel.
  8. calmnothing
    Yep it might actually fit. Unless they had to reflange it
  9. crashtke
    I usually go to private individuals when possible. This person that I used was based out of Stone mtn and did an incredible job. I had a similar exhaust made for a Honda at a shop for $85, but only one side.
  10. 1ll-WRX
    yeah for some wierd reason it goes back to 3in after the bend at the flange...so you think I could possibly get these to mate-up without leaks?
  11. nsvwrx
    nsvwrx Active Member
    thats liek the flange onmy cat back
    my dp is 3" cat back is 3"
    but the damn flange tapers to 2.5 then back to 3
  12. calmnothing
    if it bolts up and you got a gasket and maybe some silicone....it could work
  13. 1ll-WRX
    oh so this is kinda common then....you think there'd be any performance disadvantages to doing it this way?
  14. calmnothing
    Considering that you're going from a 3inch downpipe to a 2.5 inch catback it might restrict the system a bit....but it will be less noisy
  15. 1ll-WRX
    well the weird thing is the axel back is 3in but the flange tapers to 2.5 where it connects to the rest of the catless back...:wiggle:
  16. crashtke
    One reason I realy like my TurboXS...3" all the way back.
  17. 1ll-WRX
    yeah my current exhaust is 3in all the way back....but i want to see something angled instead and see if I like it...
  18. pEd
    you really won't see any performance decrease in going from a 3" to a 2.5".
    Especially that far back in the exhaust system. (some stuff I've read make it seem like you may actually pick up some power...)
    Main thing to worry about is leaking.
  19. 1ll-WRX
    yeah I'm gonna have JDM Will work his magic on it....:ddirty:
  20. Superdude
    Superdude Active Member
    sooooo, what are you doing with your old cat back?
  21. 1ll-WRX
    my random tech 3in axle back peice?.....it depends on how it sounds...i might be switching back and selling the JIC..depending on noise level....unfortunately either way I won't have the whole cat-back to sell off...
  22. pEd
    Mike (liquidforce) is selling his exhaust. Should check it out.
  23. MarkM2016GTI
    I think that it would sound very cool with an angle...Great idea Scotty B...
    Mark
  24. Alex
    Here's what he will do.
    Step 1: Cut the 2.5" piece off the exhaust.
    Step 2: Weld 3" peice and flange back on.
    Step 3: Give it back to you.
  25. scuby drew
    scuby drew techos ftws!!EEEE
    this is quite true, but you arent supposed to reveal jdm secrets mane!!! thats like taking vteck away from a honda......it would just be like mmmmmmmmmmmmmm and no BAHHHHHHHHHHHH.
  26. 1ll-WRX
    well come to find out it's an evo exhaust....:eek: ....or atleast NOT a wrx one :squint:
  27. calmnothing
    get it welded to fit
  28. 1ll-WRX
    not sure if it's worth it at this point or not...I guess I could get a quote from a muffler shop....but I kinda just want to cut my losses...I mean I already have a full 3in system, just wanted to try something different...
    edit: I talked to him and he was saying that maybe it was off his RS wagon and not the wrx....are they that different?
  29. calmnothing
    He said "maybe"? lol
    Yes they are that different. I'll tell you what. I'll trade you my Greddy Evo2 axleback (it will fit assuming you got it reflanged) for the JIC.
  30. 1ll-WRX
    or you could just buy it off the guy when I return this one for a refund?....
