Next mod?
Discussion in 'General Community' started by moose, Mar 30, 2006.
  1. moose
    OK, I feel like doing something small-ish to the car.
    Currently have:
    Rear sway from an '02 sedan
    Fastline rally flaps
    New shiny wheels and tires
    STi pinks
    VF34 P&P
    Perrin TMIC
    Perrin uppipe
    Helix catted downpipe
    Prodrive axleback
    Boost/oil temp gauges
    Turbo wrap
    Perrin ic hoses
    Thinking about:
    Short shifter
    Any suggestions? Not looking for anything big $, but I have a desire to do *something* to it. Protune will happen soon.
  2. miloman
    looks like ur good with power... i'd focus on suspension... you could:
    1) get springs: better handling & looks
    2) might wanna get rid of the 'shiny' tires :D
  3. Weapon
    if you get a short shifter stay away from the kartboy..i would suggest getting the actual STi short shifter..I agree with milo though..some springs would compliment both handling and appearance
  4. moose
    Well, the problem with springs is that they lower the car, and I don't want that.
  5. soobaroo227
    soobaroo227 Member
    Why stay away from Kartboy? I have a Kartboy and love it and have never had any problems with it.
  6. BelvnAWD
    I second that. The kartboy is awesome imho...
  7. lostinthewoods
    i would say springs. I just put mine on and the lowering was very very minor, but the handling is 10x better
    Good luck
  8. Alex
    Front sway or rear quick release strut bar?
    ss lines, better brake pads, better fluid?
  9. monk
    kris, what's up with the kartboy ss? something you ran into? i haven't had/heard any complaints thus far.
    either way moose, a ss kit will greatly improve the feel of the tranny. the stock bar and bushes are sloppy as shit.
  10. moose
    So which springs would lower the least?
  11. Weapon
    guess it was just me that had problems with the kartboy. It was the first mod I got for my car and it made 2-3 shift grind and 4-5 grind. as soon as i took it off it didnt grind anymore. :dunno . moose you could do a transmission mount..that made a very noticeable improvement on my car
  12. miloman
    siegel usually recommends tein h-techs
  13. Eh? I had the STi short shifter on my 01 RS and it was $$$$$ and a PITA..... took me like 3 hours to pull that whole stupid linkage out, and the difference wasn't that great. I had Kartboy on both my WRX's, takes maybe 30 min to do a full install, and has fantastic results. Kartboy makes some excellent stuff, I'll be putting the full Kartboy/TiC shifter and bushing combo on my STi before too long. :D
    Moose, as for springs, I vote for Prodrives
  14. moose
    I was just reading up on springs a bit and that does seem like the best option should I go down that road.
  15. Ah, gotcha.....
    +1 for the tranny mount
  16. bluetwo
    bluetwo Active Member
    I saw you have the upgraded intercooler but did you do anything about the scoops internal parts.
    In other words did you do anything to ensure that air hit the entire surface of the IC? I've been looking for a way to do that with my 06 rex since I recently installed an STi intercooler and only about half of it gets hit with fresh air.
  17. moose
    Yes, I cut up the splitter and made a new seal. The entire IC stays nice and cold.
  18. monk
    i'd say go with the prodrive springs... nice and progressive. unless you're gonna be a trackwhore when you grow up and buy coilovers later on :p
    the tranny mount is a good way to go too. there's a lot of small dollar (relatively) things that you can do that make really nice improvements.
  19. FTZ
    I have the Kartboy, and although I have never had any problems with grinding like Kris, I don't think it is anything great. I had the STI Short shifter in my old WRX and it felt more solid. I would really like to try the Perrin SS for its adjustability. The Kartboy is alright, definitely a big improvement over the stock, non shortened shifter, but just doesn' have that solid feel I liked with the STI SS.
  20. WrxCrazy
    WrxCrazy Active Member
    there is a reason some people say stay away from kartboy:squint:
    i just got my kart boy from the group buy on our fourms and my car model and everything was correct 02 wrx(simple) then the shifter came in i was happy about it, then the nightmare happens when i install it, first it's not a direct fitment to my 02 wrx, we had to cut the sides where the bolts and nuts go in to attach the gear's pully to, cut it enuff so it could match the stock shifter, wouldn't go in until we hammer smashed it in..
    thats my story with kart boy shifter, maybe micheal sent me a wrong one or maybe they come like that, now it's installed in my car, 1/2 inch shorter then my stock shifter, a little bit un ez going in 3rd gear.. :rolleyes:
  21. Alex
    It should have fit directly, thats what I never understood. I am sure you could have sent it back to Sakari and thad them look at it. Anyways, back onto topic, you are looking for springs that dont slam? Look at Prodrive. However, prodrive is eibach rebranded, so you could go straight to them as well.
  22. jt money
  23. bigb996
    springs mooooossee!
  24. WrxCrazy
    that would be nice
  25. miloman
    i am curious as to how good the progressive springs are
  26. JJang12
    JJang12 Active Member
    don't skip on braking department. With all those power mods, you can get upto high speed pretty quickly. You should balance out the braking power with your higher engine power.
  27. pEd
    +1...
    Maybe some stainless lines or upgraded pads (or both)???
  28. Goose013
    Goose013 Member
    hey moose, if you want some springs that handle great but don't slam your car as low as Alex's then go with the Whiteline Control springs. I love mine and they make a hell of a difference and I can still go over speed bumps at a good pace :)
    I think www.mastrowrx.com still has a great price on them.
    yep I checked and they're still $169 and about $14 shipping
  29. moose
    They're $229 for '04+ WRX unfortunately. Do you have any pics of how much they lowered your car?
  30. Goose013
    Goose013 Member
    I can try and get you some pics moose. I need to take some anyways
    Those guys at mastro are cool down there, if you call them they may work you a deal. they offered me the flatouts for $228 if I wanted them but I went with the controls. maybe they would knock 30 off and go halfway with you.
  31. Alex
    I'm all for a better set of pads and SS lines, it definately improves the feel of the system.
