Nos
Discussion in 'Modifications & DIY how-to' started by josh booth, Feb 2, 2007.
  1. josh booth
    josh booth Active Member
    Is any one here running nos kit on there topmount?
  2. josh booth
  3. 1ll-WRX
    haven't noticed anyone here doing it.....seen a few NX spray kits for front mounts....sorry man...
  4. crashtke
    josh are you talking about the NO2/Co2 sprayer that is supposed to super cool the intercooler?
  5. EJRex
    EJRex Member
    I think he means a tapped nitrous dry/wet nozzle in the TMIC...
    I've run it on several other cars, but not this one.. don't really plan to.
  6. GTscoob
    You really wont find many Subarus running nitrous. Most guys wont hesitate to put on meth or alcohol injection but will hate on nitrous users all day long.
    I know the meth kits tap into the topmount but I'm not quite sure what the difference would be with using nitrous. I'd say do it but datalog it a lot and start with a small shot and work your way up to a 75 or 100 shot. I've said before that in a couple of years when I can afford to blow my motor or transmission I'd love to play around with a 75 shot to see how the Subaru will take it.
  7. crashtke
    I would say on the exit side of the topmount right before the throttle body would be fine. Just make sure your WOT switch is on there and test it before running it. I see no reason why nitrous would not be fine with our cars. If you look at a lot of the REALLY fast subarus with hot 1/4 mile times, a lot of them are running a little shot of nitrous.
  8. Deke
    Deke Active Member
    Don't some people use nitrous or co2 just to spray on the intercooler. Just like the sti water spray except actually cold?
  9. crashtke
    Yup, but I have heard mixed reviews of it. You could always try it and review it for us:)
  10. EJRex
    EJRex Member
    They do, but only get minimal gains. I've never seen one of those systems give more than 2-3whp. I've never seen one on a top mount, but I assume it would be similar to an fmic.
  11. Cool_____
    Spraying on the IC is only beneficial mostly for HIGH temp areas and for people that have HUGE turbos and little dinky IC's that can't dissipate the heat well IMO. If you want to cool that air, either spray NOS into the engine or go meth injection.
  12. Weapon
    wouldnt it be cheaper to spray co2 instead of n2o?
    on the intercooler not in the intercooler of course
  13. crashtke
    Of course! Much cheaper to get refills of the C02. I think you can get a 10 lb bottle filled for around $15 of C02 vs $50 for N02.
