Not reaching target boost
Discussion in 'Modifications & DIY how-to' started by nsvwrx, Aug 4, 2006.
  1. nsvwrx
    nsvwrx Active Member
    So, isnt ap TB = 15.8+-.05?
    the max i see is 14.7 and i saw it go up to 15.1 just one time.. anyideas?
  2. moose
    It's insanely hot and humid outside.
  3. nsvwrx
    ah, that could be it =)
  4. baddriver
    baddriver Active Member
    I guess we could call it "TURBO ASTHMA" :eek:hnoes:
  5. nsvwrx
  6. moose
    I really wouldn't F with it until temps get down to low 80s or so. I had to do this when going to stage 2 (tightening the WG arm) but honestly it sounds like you're likely suffering just from the weather.
  7. nsvwrx
    alrighty then! il wait a few weeks and see =0
    not that i know how to tighten the WG arm
  8. WRX-WRC
    im still only seeing 11 peak :( but that will all change some this wednesday, muwahahahahaha.
  9. baddriver
    Would spending money for a tune in this heat make sense, and do people do say a "winter tune and a summer tune"
    Might be useful with wastegate issues with the VF39 also.
  10. nsvwrx
    i saw 15.6 today +) its hard to get this smile off my face..
    ok quick question waht exactly does targt boost mean.. as in it should be that from the tiem it spools to redline? or that should be peak?
    also, how come when i change realtime maps i cant see them in under the "current map" option, i just see the base map.
    but i know its changing maps casue i tried the anit theft and that worked.
  11. baddriver
    I wonder if it would be worthwhile, and if so would somebody could a couple datalog examples with a quick explanation of the log output and when target boost is usually achieved for the wrx and sti.
  12. goixiz
    goixiz Active Member
    you can never see real time map with the AP, it only display Base map. If you are not sure load it again (RM).
  13. nsvwrx
    ah! thanks for allt he help guys!
  14. nsvwrx
    wow, today i didnt see over 13.6... weird.
  15. moose
    If you want to datalog it sometime, feel free to stop by.
  16. moose
    Actually, since you have the AP, download TARI and log wastegate duty cycles as well as anything related to turbo dynamics...
  17. nsvwrx
    my wastegate duty cycles arnt normal at all. this is toooo weird i was lookign at someone elses and his WDC was up to 80+ by 1000 rpm mine is 0 till nearly 2k...
    weird
    wanna have a look moose?
  18. moose
    It shouldn't really matter until you get to the point where boost would overcome the actuator spring... but post a log :)
  19. nsvwrx
    well im getting SS turned soon so everythign should be perfect =P
  20. Cool_____
    It's the heat. I can't hit over 19.5 unles it is cooler than 95 out. I'm supposed to be hitting 22 psi but when I can only hit 19.5 the car is a pig (REALLY RICH AND BACKFIRES) and just doesn't have anymore power than a VF-34.
