OBD port and emissions
Discussion in 'Modifications & DIY how-to' started by yerrow, Jun 21, 2012.
  1. yerrow
    yerrow Active Member
    I went to get my emissions does this afternoon, everything was good to go until they plugged into my port.
    He was having a hard time aka unsuccessful at having his handheld connect with my ecu. Said that there was either some kind of loose wiring harness at the port, blown fuse, something stupid that was not allowing the ecu to communicate our hold a connection.
    Thoughts?
    I have almost a month to get it fixed but I still gotta figure it out.
  2. wagunz_pwn
    I have the same issue. I had my AP to prove it works. In my case, I had to hold the connector with slight pressure to one side for communications to work. Took a few tries, but we knew we had it when it didn't fail after 10 seconds.
  3. SonicBoom
    SonicBoom Active Member
    Do you have an AP to test? (or some other from of ECU reader)?
  4. goixiz
    goixiz Active Member
    shim it
    Bring some tape and ask if you could just add one wrap to the plug or connector to snug it up.
    Im in 30045 so if u like to chk i have a few obd connectors
  5. ChrisW
    ChrisW Member
    I'm in Lawrenceville too, I can try my obd2 scanner if you want
  6. yerrow
    i'll try my ap this weekend...danke
