Ohs NOs i broked the Battlewagon
Discussion in 'Member Journals & Project Build Stories' started by BattleWagon, Aug 27, 2007.
  1. BattleWagon
    BattleWagon Member
    YEAP, i broke the battlewagon, well actually it committed suicide. Spun some bearings, it was ugly.
    http://forums.nasioc.com/forums/showthread.php?t=1318406
    thats the full story
    The EJ25 is in and running good, i just put it in tuesday night...gotta brake it in and then let the VF34 rip.
    Ill post more pics of the EJ25 tomorrow night
    so now mods are:
    EJ25 shortblock
    EJ20 Heads
    Spec Lightweight Flywheel
    ACT Stage 1 Clutch
    Invidia Header
    Invidia Catless Uppipe
    IHI VF34 Turbocharger
    STi TMIC
    Perrin Catless Downpipe
    Bosal Midpipe
    Prodrive Axleback
    Prodrive Springs
    PowerSlot Big Rotor Kit
    B&M Short Shifter
  2. Hazzard
    Hazzard Member
    damn, bummer about the 2.0, but congrats on getting the 2.5 up and running. if mine ever goes, that is the route that i am planning on.
  3. Alex
    So are you blaming this on mobile 1 then ?
    Congrats on the successful swap :p
  4. Sparta
    Do u mind telling what mods u had? I recently flashed my car to stage 2 with 70k miles on it. I use Royal Purp 5W30
  5. BattleWagon
    BattleWagon Member
    i dont really blame mobil 1 cause i had castol in the car when it happened, i blame it being 5w30, its just too thin for how hot it was.
    Engine Mods when it broke
    Bosal Midpipe
    Prodrive Axle Back
    Injen short ram
    Custom FMIC
    Custom Tune
  6. GTscoob
    Damn man join the club. Good to see she's almost back up and running now.
  7. MarkM2016GTI
    I am sorry to hear about this, but on a positive note, your doing a swap, which is always cool...good luck with everything...
    Mark
  8. WJM
    You'd better have used a new oil pan/pump/sump/cooler/oil lines.
    5w-30 is not too thin unless you over temped it (240*F+ for an extended amount of time).
  9. monk
    is that the coolant reading or the oil temp reading?
  10. WJM
    Oil temp.
    SUBARU's operating temp for oil is 200~210. Really, anything over that should be considered 'too hot'...however, if you are running a high grade racing oil, it should withstand UP TO 240 w/out issues.
    However, most other high performance cars have much better oil coolers from the factory....and run 175~185 oil temps.
    SUBARU's little oil cooler (liquid-liquid type) is more of a warmer-regulator than a cooler. It gets the oil up to temp FAST and regulates it at 200~210. Works GREAT for street/autox use. Anything more, replace it with an air-liquid unit.
  11. BattleWagon
    BattleWagon Member
  12. WJM
    STi bitches!!
  13. XanRules
    XanRules Active Member
    mighty tight squeeze. But looks nice.
  14. savsuby
    savsuby Member
    I cant wait to see your car now. When are you going to come to Savannah?
  15. ScoobyMike
    ScoobyMike OG Mod
    Very nice.... ME LIKELY!!
  16. BattleWagon
    BattleWagon Member
    i might be in hilton head this weekend...maybe we can meet up somewhere sat night
  17. BattleWagon
    BattleWagon Member
    thanks dude
  18. Jewels450
    Jewels450 Member
    :naughty:
