Oil consumption 2006 2.5i impreza
Discussion in 'Modifications & DIY how-to' started by SubiNoobi, Oct 29, 2014.
  1. SubiNoobi
    SubiNoobi Supporting Member
    So my 2006 2.5i has been consuming oil for a few months now.
    Had headgaskets replaced by Allpro earlier this year. But it still consumes oil.
    No visible drips or pools of oil under the car. No obvious blue smoke coming out the tailpipe.
    What else should I look for to find the cause of this consumption?
  2. ~The_Duke~
    ~The_Duke~ Member
    How much oil are we talking about here?
    A quart every tank a gas or 2 quarts per 5000 miles?
  3. b reel
    if you have oil in the intake tract it's rings and or valve seals are shot. Did you have the heads refreshed when you had HG's installed?
  4. SubiNoobi
    I am unsure the exact amou of consunmption. The wife drives the car, so she forgets to check. However, I am sure it is more than a quart every 5000 miles. Closer to a quart every few weeks.
    I beleive Allpro resurfaced the heads. Don't know if that involved any other refreshing.
  5. nuyorican718
    nuyorican718 Member
    is your rear bumper cover black near the exhaust???
  6. ~The_Duke~
    ~The_Duke~ Member
    Odds are these things that b reel mentioned are your problems.
    The valve seals are the most likely candiate.
  7. SubiNoobi
    No, clean in that regard.
  8. SubiNoobi
    Called Allpro, they dais they refreshed the valve seals when they did the head work.
    Taking it to them this weekend to figure it out.
    Thanks for the help guys!
  9. superhawk28
    superhawk28 Member
    Have the PCV system checked.....Subaru's PCV system sucks.
