Oil Filter-When is Subaru going to learn?
Discussion in 'Modifications & DIY how-to' started by integroid, Feb 18, 2010.
  1. integroid
  2. Doug@DBW Motorsports
  3. goixiz
    goixiz Active Member
    Pure one is quite good as well but the bypass pressure is too light unless you use the one with no drain back valve (forgot the number)
  4. WRXCoupe
    WRXCoupe Active Member
    Subaru will learn when they fail, Toyota thought they could get away with outsourcing LOL!
  5. b reel
    This is really old news and practice, nothing to get worked up over
  6. Alex
    Use the H6 filter, it is JDM yo.
  7. integroid
    I already do:)
    Not getting worked up....Just sick of people trying to tell me that the Fram filter is not identical to the Subaru filter.
  8. Davidwrx
    Davidwrx Member
    Does the H6 filter fit on the 02 WRX?
  9. integroid
    Yes
  10. STI LOVER
    STI LOVER Member
    Has anyone tried the Filter that Napa makes?
  11. DaveH
    DaveH Member
    I have always used the Napa Gold oil filter.
  12. Alex
    No, and I have little interest in trying it as well. I assume you use it? What results are you experiencing?
  13. integroid
    They are Wix Filters with a different sticker on them.
    Ninja Edit:)
  14. STI LOVER
    STI LOVER Member
    And how is that working for you?
  15. STI LOVER
    STI LOVER Member
    I just put it on last week and so for so good. No problems really.
  16. STI LOVER
    STI LOVER Member
    So I'm assuming that, thats a bad thing? sorry, I've always used Mobil 1 filters.
  17. integroid
    Nope, that is a good thing. Wix/Dana make great oil filters.
  18. WJM
    Like others have said, its made by Wix/Dana. I used to work at a NAPA store and I know all the ins and outs of those filters. They are good.
    Pure one is the best outside of the Tokyo Roki filters.
  19. goixiz
    Just that the Pure one Bypass pressure for our cars are much lower than the OEM
  20. WJM
    Bypass valves suck. Every cold start, by this definition, means engine wear. Sediment settles to the bottom overnight and BLAMO, good morning engine wear.
    Also, if the filter becomes clogged, opening the bypass valve is as bad as continuing to starve the engine of oil. It will destroy it.
  21. STI LOVER
    STI LOVER Member
    Oh ok, well cool. Thanks!
    I see. I've never used one of them before. But I appreciate the input.
    Good info to know. I guess not many people are aware of that. I know I wasn't. Good thing I change my oil frequently to prevent the filter to clog. But it sucks that it still opens when the engine is cold.
  22. WJM
    I'm going to test that actually....hook up a gauge on filter inlet and one on filter outlet and see what the differential is.
  23. STI LOVER
    STI LOVER Member
    I see. I didnt think you could do that. Imma see if I can try to research it online and maybe peeps have already tried to test it. But let me know what the outcome of that is. Cuz that's interesting.
  24. WJM
    Its not hard. The sandwich adapters for oil pressure/temp is reading the oil PRE-filter. I always install the sensors POST-filter in one of the engine block main galleys.
    Measuring the oil pressure at the main galley under the ALT would be the best spot for post filter and using the sandwich adapter would be the best spot for PRE-filter.
    If the pressure differential is............?????????? I dont know...need to hook up and find out.
  25. integroid
    Just a FYI - I picked up a few Denso Oil Filters last night. They were listed for 2002 Acura TL and when they came in, they are the exact same size as the H6 filter I have in the garage. They are very nice and I have read great reviews on them. They make the OEM Toyota oil filters and I believe use to make filters for Honda as well. They came with the o-ring pre lubed which I thought was a nice added touch. Will, you want to cut one open after I use it to see if they are worth a shit?
    EDIT: LOL, after some research it appears both the Acura TL and H6 filters have the same part number from Denso. Maybe that is why it is the same size:)
  26. WJM
  27. Mad Mallard
    Mad Mallard the mad mallard
    Necropost.
    This Denso in the amazon link fits the 2.0 also? If its a good filter, it seems like a steal...
  28. integroid
    yes, it should fit. I know a lot of people using H6 filters on WRXs
  29. Alex
    Ive read on IWSTI that they're using the S2000 filter with good results.
  30. motomark
    motomark Loudest fuel pump Tucker Supporting Member
    What filter has good construction AND has the same bypass valve pressure as stock? Or is the answer none, which is why we keep going in circles???
    Seriously it would be great if Will could provide some real empirical data provide a couple of different part #'s/ close the thread and sticky it. I would seriously donate $20 to Will to destroy a couple filters and find out real data relevant to what makes an excellent/good filter.
    Bye... I'm going to bobistheoilguy for a few hours so I know which oil of the month to use in my next oil change.
  31. Alex
    I'm still loving the H6 thanks to Eddie and Will ;)
    Keep you eye on IWSTI and NASIOC FS, sometimes you'll see the original black STI filters come up in a 6 pack.
  32. integroid
    Why not just use the H6 Tokyo Roki filter?
    I have used the Denso filter and they seem very nice and have been well reviewed on a few sites.
  33. blindfold
    blindfold Active Member
    and how much do they go for?
  34. Mad Mallard
    necropost again. i finally used the Denso i got off of Amazon for $5.50 before the price shot up.
    good grief this h6 filter is huge, the element inside has to be close to twice as much area as stock and stock replacements. O_O
  35. Alex
    The h6 is awesome -- its like an oil rich hot tub for your motor.
  36. Fafnir
    Fafnir Member
    This is really interesting. I wasn't aware that this was an issue in our cars. Is the Denso 150-1006 an H6 filter, and what most people use as a replacement?
    I've been using Purolator PureOne filters for a long time, because of the good things I've read about them. Never caught this bypass pressure issue, though.
    I've got a 2006 WRX - I guess the Denso 150-1006 fits?
  37. integroid
    Yes or you can get the pure one filter for the H6. Just look up the filter for a Tribeca. A lot of people are raving about the OEM Mazda RX-8 Filter on the Legacy boards. I havent had any problems with the Denso or the Pure One filters.
  38. WRboXer
    WRboXer Active Member
    Ok, has anyone ever had a problem with any oil filter?
    Ive been through my fair share of cars, and have pretty big list of car buddies. Poor oil filter performance has never been discussed or brought up?
    What does a poor oil filter do badly?
    What does a good oil filter do well?
    I am mostly interested in what filters to pass on rather then what filter is the best. I have always used a modil 1 wrx oil filter, are those any good?
  39. integroid
  40. integroid
  41. Alex
    S2000 Filter Discussion? :)
