Oil pick up tube fix
Discussion in 'Modifications & DIY how-to' started by JDM-STI, Jul 11, 2008.
  1. JDM-STI
    JDM-STI Member
  2. Batlground
    Batlground Active Member
    I don't think welding a thicker tube on there is going to help anything.
  3. JDM-STI
    JDM-STI Member
    Originally Posted by sti_rules
    The wall thickness is .109" vs. the factory .035" It is tig welded and not brazed. My goal was to take advantage of the thick flange to strenghten the known break points of the tube. I was concerned about making the whole thing beefy in that it would add weight far away from the fasten points (flange and bracket) and that can create excessive vibration is the assembly and possibly stress the fasteners. Is is much stronger and has less deflection compared to the factory unit.
    A little more info.
    I think that a tube that is 3 times thicker will be much less likely to break.
  4. FACE
    I would be worried about it breaking at the other end looking at that...
  5. crashtke
    Seems like a better method may just be to reinforce the existing pickup rather than replacing anything. I would be curious to see exactly where all these things are breaking at...from there just reinforce or brace and you should be good.
  6. JDM-STI
    JDM-STI Member
    They are breaking about a half inch below the flange brazing. That's where the it sees the most vibration. The pick-up end is submerged in oil so the vibration on that end should be greatly dampened.
  7. mmtasty
    mmtasty Active Member
    actually, it just may do it... the problem was the overheated weld and vibration. It may just be enough strength to calm the vibration and a little larger area to weld the top.
    I think a gusset is all that may be needed. somehting to add a little strength to overcome the vibrations.
    I'm not worried about the bottom (pickup) snapping because it can move with vibration. it's not fixed and being leveraged by anything.
  8. Batlground
    You guys do realize that the tube is going to get really hot when you are tig welding it.
  9. JDM-STI
    JDM-STI Member
    Regardless, I think this is much stronger that just leaving it alone.
    We need some type of fix for this issue besides having to do a Moroso oil pan.
  10. Batlground
    I agree there needs to be a fix but tig welding the tube is just creating another weak spot, Tig welding takes more heat than brazing.
  11. nicad
    wait...what? so? if done properly it won't 'create another weak spot'
  12. FACE
    Here's where mine broke...
  13. Cool_____
    Kartboy was supposed to look into make one but never heard anything else about it. Anyone have a hookup with Tom @ Kartboy?
  14. WRXCoupe
    WRXCoupe Active Member
  15. nicad
    making these would be pretty trivial. whats the oem material, carbon steel? diameter of the tube? I've probably got a shitton of 304SS at work if anyone wanted me to make one
  16. JDM-STI
    JDM-STI Member
    I'd be game for anyone coming up with a fix. Replacing the oil pan just for the pick up isn't worth it to me. All I need is a tube that won't break. The rest is overkill.
