Ok im bitten and Im goin to get the AP
Discussion in 'Introduce Yourself' started by goixiz, Jan 25, 2006.
  1. goixiz
    goixiz Active Member
    Im getting a semi used - open box only never linked, according to seller.
    Besides making sure that it is Unmarried (suppose to if not connected) are there any questions i need to ask seller before i paypal. And What should i be cautious about. Thanks
  2. miloman
    ask him if he bought it from genya :keke:
  3. moose
    Just make sure you get the cables and power adapter. Since your car is an 05 (right?) it'd be a good idea to ensure you have the '05 firmware. Cobb says it might work to load 04 maps or 05 maps with the 04 firmware... but I did not have much luck there so ended up going to 05 firmware to make things easier.
    Sorry if this is confusing. :) When you get it let me know what the screen says when you boot it.
  4. Alex
    Good luck :)
  5. SonicBoom
    SonicBoom Active Member
    Make sure it comes with the the green and white connectors...
  6. moose
    Errr... the green connectors better be firmly attached to your car or there's something seriously wrong with it.
    You do need to make sure the white connector comes with it though. The green ones are under the dash of your car and you just connect them to go into diagnostic/test mode.
  7. Superdude
    Superdude Active Member
    So, did you get it? Reports? This might be my first power upgrade, so i'm very courious. :sx: i think we both asked moose a ton of ECU questions.
  8. Alex
    Yeah, what's the results here?
