Old retard finally opened up my stock 5MT
Discussion in 'General Community' started by Cool_____, Apr 11, 2011.
  1. Cool_____
    My old stock 5MT lived at 350 hp for 97000 miles and 500 drag launches before 3rd gear let go while simply passing a car casually (not WOT and only pressed gas to pass and maybe 5 psi). I got a 6MT and gave the busted 5sp away.....dude finally opened it and sent me the pics of it.
    Yup 3rd gear is SHREDDED.
  2. cMags
    cMags Member
    Crazy. I saw a couple shredded gear sets like that on the used parts shelf at AllPro yesterday. What year 5MT was that? Was it one of the older "glass" ones or the beefier newer one?
  3. Cool_____
    2004.....the beefy kind. It helds it's own at 500 drag launches....prolly 50 of them were 11 sec passes.
  4. nygiant
    nygiant Member
    considering the power levels, number of miles, and your 500 launches....i think it held up pretty well. what year trans?
  5. Cool_____
    beat ya to the reply but it was a 2004 wrx
  6. Alex
    Interesting. Thanks for the pic.
  7. Trancetto
    Same happened to my old transmission. I was driving normally and third just gave out. That is why my name end it up being brokenwrx. lol
  8. John
    John Active Member
    The clutch in my old Legacy failed under normal driving when shifting into 5th (center shattered)....but that was after A LOT of abuse.
    They never seem to break while you abuse them lol
    HAHA - A guy on LegacyGT.com is telling me that you can't hit 400hp on any 5MT. I would think if you can do 350hp for 97000 miles, then 400 would be doable as well
  9. jeb
    jeb Member
    I think once you get to around 350 whp its not a matter of if they will fail but when. Mine failed almost the same way but it was second gear. Rolling up to a stoplight, down shifted and second went out. It was probably around 3000 rpms.
  10. John
    John Active Member
    any car part failure is a question of when and not if. it just happens faster when you add more power to them
  11. Jake
    i was curious on your PPG forsale thread what the 'infamous' 4th gear synchro in wrx trannies is?! i've heard of 2nd and 3rd gear going out all the time because of either too much power, or shitty drivers.
    ps. i know it wasn't you who said it, just bringing it back up. cuz im unaware of it
  12. Cool_____
    I dunno man but the 2002 bugeye my coworker has with 130K miles and 333hp, my old one, and the 2002 wagon with 140k here at work has ZERO synchro issues. Now they all had the hard to get into 1st/reverse at time but if you pop into 2nd then 1st/reverse it slid right in but NEVER had synchro issues while moving.
  13. Jake
    i never had any synchro issues. the only 'common' issue i've heard was 2nd or 3rd exploding when someone shifted like an asshat, or had ~400+tq. my front diff exploded, but that was due to a wreck i had where the driver's side wheel was hit and knocked the front diff out of alignment, causing it to eat itself
