P0420
Discussion in 'Modifications & DIY how-to' started by Dheim96, Jan 8, 2012.
  1. Dheim96
    Dheim96 Member
    Im driving back from MD with my car and I get off the my exit in GA. As soon as I get off the check engine light comes on and the cruise control light is flashing. I went to autozone and had them pull the code. It's a P0420. Anyone ever run across this? Could be a bad O2 sensor, ignition system or A/F ratio is what they said.
  2. integroid
    Do you have a catless downpipe?
  3. Dheim96
    Dheim96 Member
    Stock downpipe
  4. b reel
    question is do you have an AP or open source tune? The code can be turned off
  5. integroid
    yeah but why is it coming up to begin with when he has a stock downpipe. Clear the code and see if it comes back. It might have been a fluke.
  6. wagunz_pwn
    Probably a bad O2 sensor.
    You could also try cleaning your maf.
  7. Dheim96
    Dheim96 Member
    I don't have either.
  8. Matt
    catalyst inefficiency is typically a bad o2 sensor.
  9. GTscoob
    Most definitely if the rest of the car is stock.
  10. Dheim96
    Dheim96 Member
    So, the check engine light went off yesterday. I didn't do anything. works for me.
  11. integroid
    It will go off after a few hours of driving. I would get it cleared and then see if it comes back on.
  12. Dheim96
    Dheim96 Member
    The weird thing is that the light was on for about 4 days and then just went off yesterday.
  13. Jake
    it does that. doesnt mean the O2 magically fixed itself. its still in there.
  14. Dheim96
    Dheim96 Member
    I'll have autozone clear the code and then see what happens.
  15. CelticPride
    CelticPride Banned
    o2 doesn't fix itself....it just didn't pop that code again in so many drive cycles.
    If you as much as look at the o2, it'll die on you :|
