P1152 cel code???
Discussion in 'Modifications & DIY how-to' started by keeganxt, Oct 14, 2007.
  1. keeganxt
    keeganxt Active Member
    I'm currently throwing
    P1518 - Starter switch circuit low input
    P0851 - Neutral switch input circuit low
    P1152 - O2 sensor circuit range/performance (low) bank 1 sensor 1
    P1152 - O2 sensor circuit range/performance (high) bank 1 sensor 1
    Anyone know the cause for these and other solutions. everytime i search on nasioc it's just a list of the codes or someone asked about it and no one gave any answers except... duh "it's probably the o2 sensor"
    so does that mean replace it or what.
    i'm running a catless invidia divorced wastegate downpipe with a spark plug defouler installed on the o2 sensor already. the cel only comes on after running the car for an hour or so straight. sometimes longer.
  2. Jake
    P1152 is just your O2 sensor getting bad signals i believe. cause of the aftermarket exhaust. i threw that one, had it cleared at advance and never saw it again.
  3. keeganxt
    well i keep getting this and it sucks cause it's always on the highway, and the cruise stops working. i can clear them all day with ecuexplorer but i need a solution, and the started ones are very weird too, unless those come up when the ignition is on but the engine is off and codes are read.
