P2021
Discussion in 'Modifications & DIY how-to' started by Greg, Oct 14, 2007.
  1. Greg
    Greg Active Member
    2021 is TGV Position Sensor 2 Circuit Low... This code came up after I reinstalled the engine, but to my knowledge the sensor(s) weren't unplugged, so any suggestions?
    Also, what would this cause? It isn't smooth under power, it stutters a little all the way through thr RPM band...
  2. Sparta
    It might be that bolt I used on my rotors causing this
  3. Greg
    Greg Active Member
    haha, you ass :)
  4. Jake
    that would definitely cause what you are describing. if there is a problem not allowing the TGV (tumbler valves) to not open fully then obviously not enough air or perhaps too much air at the wrong times can cause stuttering or hesitation.
  5. Greg
    Greg Active Member
    So you think the sensor is bad completely or what? How much are they?
