paint crack in front lip
Discussion in 'Modifications & DIY how-to' started by SubiNoobi, Apr 27, 2007.
  1. SubiNoobi
    SubiNoobi Supporting Member
    I have a very small crack in the paint on my front lip. The crack is in the corner where the lip juts out from the vertical piece. The crack is only a few millimeters long, but I want to stop it from spreading.
    I have some subaru touch-up paint, but I was wondering if primer and sealer or polyurethane would help seal up the crack?
    Any ideas?
    Thanks!
    -Matt
  2. AtlxPat
    AtlxPat Active Member
    oh no! its cracked? well my friend has a type-r wing on his type-s and it has a crack, he painted it anyways and its spreading slowly. so i doubt you will stop it from spreading, but then again its polyurethrane
  3. clemsonscooby
    clemsonscooby Active Member
    I've used the midnight blue touchup paint found at Advanced Auto Parts when I was cutting my fenders. It worked nicely and the paint match was pretty good. It said it was for a Honda, but I couldn't tell the color difference.
  4. SubiNoobi
    its not on the aftermarket black lip, its on the original painted lip that the black lip is attached to. I would be very surprised if the polyurethane lip cracked.
  5. AtlxPat
    ohhh, i was about to say how did that happen, as for touch up paint...i have no idea
