If I get an Ecu reflash (via ECUtek) from PDXtuning, will custom dyno tuners be able to tune the setup without installing their own ECUtek software? The only reason I ask is that I would be able save from the intial ECU install from a custom tuner. Basically, I would get the stock ECU reflash from PDX (about $700), then use a custom tune for any additional modifications in the future, assuming of course that this kind of route is possible/a good idea. Thanks a bunch.
yup... u can buy the license and get the initial flash anywhere... in the future ecutek tuners can tune ur car for an hourly rate
Why not spend the $700 at a local ECUtek tuner and get the first hour of tuning for free. That is a wise decision.
Of course, that would be the best option, but I thought topspeed or SOG were the only (quality) ones around here. The only reason I'd do PDX is to save money. But if a local tuner would do the same thing for the same amount or even a little more, it'd be worth it.
i believe both topspeed and SOG wont be able to sell ecutek under 850... remember, that does include some tuning
Thanks for the info. I did not know that the initial ECUteking included some tuning also. Pretty much clears that up.
