? Perrin FMIC w/APS CIA
Discussion in 'Modifications & DIY how-to' started by oneiguy, Dec 21, 2008.
  1. oneiguy
    oneiguy Active Member
    Apr 18, 2007
    1,162
    0
    Has anyone seen this combo? I tried to install both today, but there wasn't enough play in the wheel well for both. Any suggestions? Or do I need the Perrin intake?
  2. pEd
    Mar 5, 2004
    2,460
    3
    I'm pretty sure you'll have to have either the Perrin CAI or the APS front mount.
    IIRC, each front mount uses a different hole on the intake side for the intake and cold side of the fmic.
  3. Jake
    Jul 8, 2006
    3,845
    0
    isn't the cai two piece? I thought it could be used as both a short ram and cai. If that's the case why not just use the short ram temporarily until you can get the right one or trade someone
  4. G-Man04sti
    G-Man04sti Member
    Nov 14, 2008
    51
    0
  5. Jake
    Jul 8, 2006
    3,845
    0
    ^^ there you go, it will fit without a bracket
  6. oneiguy
    Apr 18, 2007
    1,162
    0
    Well looks like we will have to give it another try
  7. Cool_____
    Sep 5, 2005
    7,338
    0
    I had it on my car at one time but the filter and the piping will push on the wheel liner BAD. Also I had to take an adapter to turn the filter inwards. Your wheels will rub the liner if they are big enough. I ended up taking it off.
    #7 Cool_____, Dec 23, 2008
  8. Alex
    Alex Community Founder
    Staff Member
    Oct 7, 2003
    15,892
    20
    I demand pics!
  9. Cool_____
    Sep 5, 2005
    7,338
    0
    No longer on my car so I can't give that to you. Why do you demand pics? Aren't you TMIC?
  10. oneiguy
    Apr 18, 2007
    1,162
    0
    If we manage to get it on I will post some. I am only running 17x7.5
  11. Cool_____
    Sep 5, 2005
    7,338
    0
    Your fender liners will still get pushed out a little. I used a 90 degree elbow on the end of the pipe so that the filter wasn't rubbing the piping. That metal on the filter will rub right through the metal piping over time.
