Hey guys Im trying to get a good sway set up here in the next couple of weeks. There are so many set ups im lost. My wagons a DD, but i still want a tight set up so i can run at the track. I basically want a little go cart with some oversteer, Set up suggestion? Oh i have Megan racing coilovers if that matters.
27mm It can be done, wagon or not. The difference between a wagon and a sedan sway bar is very small and can be made up for with spacers. The bigger difference is between turbo and non-turbo bars, because of exhaust header clearance, But if you have a turbo, then you can run whatever bar you want, just get some upgraded wagon endlinks as well. You may not need as big as 27mm, but it feels great.
I think the biggest wagon front is the 24 or 26 from Whiteline, definitely get that one. Then get the 22-26 rear from Whiteline. Give us a call on Monday and we can order it for you. Siegel
Just so you know, this is what happens when you put a sedan bar on a wagon - Whiteline 27mm adjustable (36XXZ): As you can see, the issue is not with the length, but with the angle of the tabs. The clearance was tight, but gave me no issues, of course with a turbo, you won't even have this problem at all.
