Pillarless grill??
Discussion in 'Modifications & DIY how-to' started by nik_05STi, Jul 15, 2010.
  1. nik_05STi
    nik_05STi Member
    How easy is it to take the center piece completely off my '05 STi grill. If i take a dremel to the top and bottom and smooth it out, would that be considered done?
  2. FTZ
    You can use the dremmel to cut the pillar out, but not to smooth it out. Most likely, you will need to use Bondo to fill in a little where the Pillar connected at the top and bottom and paint it.
    Here is a good write-up with pictures of the process.
    http://www.wrxtuners.com/forums/f93/how-debadge-04-grill-9076/
  3. nik_05STi
    nik_05STi Member
    Thanks 420
  4. nik_05STi
    nik_05STi Member
    by the way, it mentions semi-gloss/satin black paint. Is that the correct color of the grill?
  5. Matt
    at that point, you can paint it whatever color you want to. :)
  6. Trey
    Trey Active Member
    Electrical tape works well too. No one seemed to notice mine. :p
  7. FTZ
    Alex might be able to chime in on the correct paint color. I know he did his a while back. I would like to remove the pillar on mine soon.
  8. Alex
    Semi-flat is my preference but it's been pulled from the shelves. Grainger carries it in their warehouse I think still.
  9. nik_05STi
    nik_05STi Member
    i might use that electrical tape process temporarily, doesnt look that bad
  10. FTZ
    Trey, can you post a close up of your grill?
  11. Alex
    Use bondo and do it correctly :)
    And fwiw, I have been contemplating re-painting mine in a gloss.
  12. JAES
    JAES Member
    nice
  13. b reel
    use Evercoat body filler and it will be better
  14. Trey
    Trey Active Member
    It's gone. It looked fine, I left the cut part a little high so I could grind it smooth...oneday. :p
