Pioneer Avic D-2 hookup
Discussion in 'Modifications & DIY how-to' started by sm04subaruwrx, Nov 16, 2006.
  1. sm04subaruwrx
    sm04subaruwrx Member
    I'm installing a Pioneer Avic D-2 navigation system into my WRX and was wondering if anyone knows the easiest places to tap into the speed sensor, emergency brake, and reverse mode.
  2. thebigph
    thebigph longing for another subie Supporting Member
    go to www.avic411.com and you'll find everything you need to know. i cant answer off the top of my head without looking at my setup, but this website is very extensive in the avic products. and ducatiboy knows his shit. look aroud first before you ask particular questions b/c most likely the question/answer are already on the site. good luck
  3. sm04subaruwrx
    thanks. we are going to try to install it this weekend so i'm going to check that out.
  4. thebigph
    no prob i have the avic z1 and the only difference really is the dvd watching capability and the hard drive. all features on it are bad ass and you won't be dissapointed. let me know how it turns out. plus the fit is amazing and looks good in the dash
  5. bigb996
    you can go to the ignition harness and a lot of the wires will be there, the ebrake should have a wire run to it. The console pulls up withthe removal of 2 screws on the inside.
  6. sm04subaruwrx
    where is the ignition harness? my brother and i are going to try to do if over thanksgiving break cause we'll both be home from school. i hope we get it done finally cause it's just been sitting in a box for a couple of weeks. he's been checking out that site posted earlier already.
  7. bigb996
    ignition harness is located up under the dash near the stearing column..
