So I'm looking at my car this morning in a parking lot, and it seems like the right side is a little higher up than the left side. I have an Eibach Pro Kit, is it possible that always having a driver without usually having passengers could cause the springs on one side to sit lower than the others? I don't think a 150 lbs could make that big of a difference, but if not then what could do that? I'll have to take out a measuring stick later and check for sure. Craig
make sure the car is perfactly level when u measure it. some times you eyes can do weird things:werd:
Go measure just about any car, and you'll likely find differences in ride height between the wheels... my '97 Formula sat 1/2" higher on the driver's side. Of course, worth checking out, but there may not necessarily be anything wrong.
On perfectly flat ground my front left is 1/4" lower than my front right, and my rear left is 1/2" lower than my rear right. Could be tire pressures though, some look a lil low. Will put air in and see then. Craig
