Powder Coating Perfection
Discussion in 'Modifications & DIY how-to' started by 07Ltd#767, May 26, 2009.
  1. 07Ltd#767
    Want to give a shout out to Breel for taking the time to powder coat just about everything...
    Exhaust Manifold AND Stock Heatshield
    Hotside of Turbo
    Valve Covers
    TGVs
    Intake
    Uppipe
    Downpipe
    All IC Piping
    I'm not sure if he may sign up as a vendor and offer these services out, but he should...I'm pretty sure it would be very competitive when compared to local shops.
    Woohoo for purty engine bays :wiggle:
  2. calmnothing
    Looks awesome
  3. goixiz
    goixiz Active Member
    Powder coat or thermal coat ?
  4. Jake
    Nice, we'll need a fully installed shot
  5. b reel
    The flat black is a ceramic powder mix and good for 1000 degree constant. I've shot quite a few exhaust manifolds, headers and two blown dragbikes without a single problem. The bikes have two seasons each and look as fresh as the day I shot them. It's all in the prep before coating that makes the difference.
  6. Ben@TTR
    Ben@TTR Member
    yeah brian does good work
  7. pEd
    damn... looks like he did a good job on the dog leg as well.... :rofl:
    Good job Brian!!
  8. goixiz
    thats call the fur coat and it will cost extra
  9. FACE
    Looks awesome man! Nice work Bro!
  10. ScoobyMike
    ScoobyMike OG Mod
    Looks so hot dude!!! I love it!! Great job!!
  11. 07Ltd#767
    we were working on it outside late last night and the lighting was so bad the camera couldn't pick up how good it actually looked. I'll try and get out there today while it's still daylight and see if I can't get some good ones
  12. Sparta
    Finally we might be able to see this bitch get put back together
  13. b reel
    Could have had the same, but noooo. I hope you took my advice and put a quick coat of clear satin on the TGV's.
  14. slowwrx
    LOL...the Maf flange is backwards....might need to coat the intake pipe again.
  15. Doug@DBW Motorsports
    is that 1000 c or 1000 f ?
  16. b reel
    good question, will be back with answer....
  17. b reel
    that would be with a "F"
  18. wishiwuzfast77
    wishiwuzfast77 New Member
    know you got to powder coat your hood man:bowdown: dont think it will fit in the oven though.....
  19. b reel
    Have access to a 8'Hx12'Wx20'L oven to do it in. The only draw back is that my fiberglass would ignite
  20. wishiwuzfast77
    here that .... i wanna do my rims oz white ....
  21. blindfold
    blindfold Active Member
    so 1000F should be able to withstand th heat produced correct? Thanks
  22. Alex
    Good question, curious as well. Even though I have yet to install my EGT, I was under the impression that cruising temps are somewhere around ~1400F 'ish ?
  23. b reel
    You may see those temps at the first bend of the exhaust manifold or header but drops from there. Now if your running 30psi at 9K rpm for 500 miles you may see hotter constant temps but for most applications in regards to cars on this forum, if your hitting that high of temp, you better be prepared to buy new pistons and turbo.
