Problems Separating Rotor from Hub
Discussion in 'Modifications & DIY how-to' started by Electioneer, Jul 29, 2012.
  1. Electioneer
    Electioneer Member
    I took the hubs off of my swap car with brakes in tow (Caliper+Rotor). The caliper had no issues coming off but the rotor just won't budge. I have pretty much drowned the thing in PB blaster, wailed on the thing with a hammer (not using the rotor so I'm not worried about damaging it) and still no dice.
    It is like this on both sides, I haven't found any set screws or holding pins.
    What am I missing?
    Take care,
    Reed
  2. wagunz_pwn
    I thought you had to screw in a bolt into that hole on the front face the rotor and tighten it until it breaks free.
  3. tallgeese2
    tallgeese2 Member
    what kinda car and where u located at?
  4. h23bb2
    h23bb2 Member
    reed, do you see two threaded holes in the rotor hat?
  5. Electioneer
    Electioneer Member
    Threaded holes. Bolts. I am an idiot.
