PS3 help needed...
Discussion in 'Gaming' started by SonicBoom, Jun 13, 2008.
  1. SonicBoom
    SonicBoom Active Member
    We'll I guess any online gamer will be able to answer this.. I just bought a PS3 and need to know what I need to get online. Here is my current set-up... I have a cable modem thru Comcast. The modem is by the TV and where the PS3 will go.. I have no wireless router or any router for that matter.. The modem only has one port thats not in use, and I've been told its firewire(triangle looking, with a raised square in the middle). The PS3 comes with an ethernet cable... I'd rather not go wireless if I don't have to, since everything is right there together... but if it makes more sense or is easier I'm not against it. So basically, I need to know what items I'll need, best brands at the best price etc...
  2. nicad
    get a router. they're cheap
    where is your computer in all of this? plugged into the ethernet port of the cable modem?
  3. SonicBoom
    ^^^ Yes, the pc is hooked up with the ethernet going to cable modem... So.. could I just hook up my PC's ethernet cable into the PS3 for a temp fix?
  4. nicad
    no. you'll need to get a router, and hook the PS3 and PC into the router, and the WAN side of the router to the cable modem.
  5. nsvwrx
    nsvwrx Active Member
    yeah, if you just wanted to get online hook the cab in to the ps3. better solution is to get a router.
  6. SonicBoom
    ^^^ Whats the 'cab' ?? Yeah, I'll be purchasing a wireless router this weekend...
  7. nsvwrx
    rj45 cable
  8. SonicBoom
    ^^ Oooo Kayyyy... whats a rj45??? Maybe I forgot to mention I'm an audio/video retard(no offense to mentally handicapped)....
  9. nicad
    step 1: buy a router, don't spend more than $50
    step 2: plug computer and PS3 into ethernet ports on router
    step 3: plug cable modem into external/WAN side of profit
    step 4: ????
    step 5: PROFIT
  10. SonicBoom
    ^^^ lol... thx.. think I have a handle on it pretty much. I plan to go wireless though, and I know that PS3 is allready set-up for it, I assuming my PC is going to need a wireless adaptor. What exactly are they called(or is it just wireless adaptor) and how much should I expect to pay? The routers I've been looking at are between $30-40...
  11. nicad
    you won't need a wireless adapter for your PC. just get a router with a built in switch (it will have ethernet ports on the back, around 5 ports usualy). 4 will be for devices you want to have internet access, and one will plug into the cable modem. think of it like a TV splitter. one cable goes to your cable modem, other two go to your PS3 and PC. you can keep both of them wired, both wireless, or a mix or whatever the fuck you want.
  12. SonicBoom
    ^^^ k, makes sense... I still don't see how the PC will recognize the router if I go wireless... There'll be no ethernet cable from PC to router... I know, I know... its not that difficult, just never worked with it before...
  13. nsvwrx
    a wireless router can still have eathernet cables
  14. nicad
    most routers will have wireless and wired adapters on them
  15. nsvwrx
    if you need help i can help you with this.
  16. SonicBoom
    ^^^ Thx, I'll def be taking you up on that... I really want to get rid of the ethernet cable going to my PC, in crosses my front door.. is ugly, and a tripping hazzard. So if I'm getting a wireless router, this would solve my dilemma..no? So, do I need a wireless adaptor for my PC or no?
  17. nsvwrx
    Yes, you would.
  18. SonicBoom
  19. nicad
    those are fine, use newegg.com might be cheaper
