"Pulsating" while in boost
Discussion in 'Modifications & DIY how-to' started by jautry27, Apr 7, 2013.
  1. jautry27
    jautry27 Member
    I'll try and describe this as best and accurately as possible. I've just noticed this over the last couple of days. Kind of came on all of a sudden. When I am pressing the gas, I've noticed that the engine surges a little bit while in boost. Almost like you would be slightly letting up and down on the gas while accelerating. I notice it more often at lower RPM's while in a higher gear.
    I've read a couple places that have said a possible boost leak. I haven't checked my lines yet, but will tomorrow as soon as I get some more daylight.
    Any thoughts or has something similar to this happened to any of you?
  2. techlord
    Always look for the post maf leak but don't be surprised if its a coil pack
  3. jautry27
    jautry27 Member
    I can only assume that I should hope its the post MAF....I haven't even looked at the price of a coil pack, but can only assume it ain't cheap.
  4. jautry27
    jautry27 Member
    Maybe the Fuel Pressure Regulator?
  5. Jake
    coil packs can be found cheap used, just make sure they are good. do you have any check engine lights? if you have a misfire in cylinder 1 for example, move that coil pack to cylinder 2 and drive again and see if the check engine light follows it. this will narrow down which coil pack is back and if that is indeed the problem. its actually a pretty common issue with both WRX/STi's.
    otherwise, pull your intercooler off (assuming you're still topmounted) and check all around the intake elbow (could actually be the intercooler lines too). but this is the only real way to be sure.
  6. jautry27
    jautry27 Member
    No check engine lights. I figured if it was something like a pack, the light would come on. Since it has not, I kind if figured it could be te FPR
  7. integroid
    The light will not come on unless it starts to misfire. A coil pack can still be going bad without the light coming on. Bad FPRs are not a common problem on Subarus. Techlord and Jake are on the right track.
  8. CelticPride
    CelticPride Banned
    Post MAF leak, IC leaks, check coils. Do you have a boost gauge? This actually sounds like boost/fuel cut. Is the boost going up then down and repeat? If so you could have mechanical boost creep or the the WGDC is all out of whack (I had that problem once). The boost would go from 20 to 15 to 20 to 15 exactly in the situations you described.....lower rpm high gear (more load). I see you swapped the EJ255 for a EJ257 so your compression has dropped on your car therefore if you are not custom tuned your maps are tweaked.
  9. jautry27
    jautry27 Member
    It's just a 257 block, but still the lower compression pistons. I do have a boost gauge. Not a fancy one, but seems to be pretty accurate. It's usually 7-10 and back to 7, but not a flickering type of fast. It's more like letting up and down on the gas kind of rate, but the whole time, I will be at WOT.
  10. CelticPride
    CelticPride Banned
    Did you reuse the EJ255 pistons or used EJ257 pistons? EJ257 lower compression than EJ255 iirc. Like 8.4 vs 8.2.
    My old issue did not flicker fast. It would build boost and fall build boost and fall just like you were getting on and off the gas. It was a very smooth build/fall and the culprit was a bad wastegate duty cycle in the tune itself.
  11. goixiz
    goixiz Active Member
    remove vac line to WG and drive normal and then get some boost and see
    WGDC
    Q:
    Did you adjust the WG arm (if adjustable) ?
    Did you do anything to the BCS ?
    Did you change the PID or WGDC or boost targets (maps) ?
  12. jautry27
    jautry27 Member
    It's all 257 block (pistons, rods, crank, block). Everything else is 255. The way you are describing it is almost to a tee. I've got someone who is going to look at it tomorrow. He came recommended by B Reel, so I'm sure it'll be taken care of.
  13. CelticPride
    CelticPride Banned
    Do what goixiz said to do.....may boost lower in total but the boost should hold steady. If so then that is exactly what it is.
  14. jautry27
    jautry27 Member
    Ok, so I did what he said and it does build evenly now, but according to the gauge, it won't release until I let off the gas. It was reading as high as 17-18 and would release pressure until I let off the gas.
  15. jautry27
    jautry27 Member
    Nothing has been adjusted.
  16. goixiz
    who tuned it ?
    target boost ?
    I would lengthen the WG arm 2 turns for now till you retune
    Your PID values may be too high
  17. jautry27
    jautry27 Member
    Stock tune. Target boost= whatever is stock.
  18. goixiz
    So you did a major mod and was not tuned ?
  19. jautry27
    jautry27 Member
    I was told by the person that I bought the engine from that just by adding only a 257 block, that I would not need to re-tune it. As I said, the only thing about my car that is 257 is the block (block, pistons, rods, crank). Everything else is 255. But then again, I was given a lot of bad advice when I was building this engine.
  20. jautry27
    jautry27 Member
    And when I say bad advice, I'm not referring to any that was given to me on here.
  21. CelticPride
    CelticPride Banned
    17-18 psi on WG pressure? Something isn't right here. Are you sure you pulled the wg line off cause on a stock turbo I think that wg is only 7-8 psi or so.
  22. CelticPride
    CelticPride Banned
    And yes you changed the block/pistons to a lower compression one. Your stock tune is not optimal. Even in stock form your stock tune was not optimal.
  23. wagunz_pwn
    Wait, wait, wait...you haven't been tuned?
  24. CelticPride
    CelticPride Banned
    Nope. Changed the effective CR of the engine and left the tune on the EJ255 settings.
    jautry who is looking at your car that b reel recommended? Mike Sargent perhaps?
  25. wagunz_pwn
  26. jautry27
    jautry27 Member
    A guy named Steve. He calls him chicken biscuit. He's gonna look at the tune
  27. jautry27
    jautry27 Member
    There's only one vac line to the WG, right?
  28. CelticPride
    CelticPride Banned
    Yes one line to WG.
  29. jautry27
    jautry27 Member
    Then I pulled the right one
  30. CelticPride
    CelticPride Banned
    Let us know what you find out. In the meantime I'd stay away from WOT. But get that thing tuned.
  31. jautry27
    jautry27 Member
    I'm going to meet with him Saturday instead. We just didn't have time today.
  32. CelticPride
    CelticPride Banned
    So what's the issue?
  33. h23bb2
    h23bb2 Member
    We still haven't met up to log the car...
    9/10 the EBCS goes bad in these things. I have a handful of spares from customer's cars but IDK if I was bright enough to mark/ditch the bad ones... lol
    Steve
  34. jautry27
    jautry27 Member
    I've just had a bad string of luck lately and haven't been able to make it that way.
  35. jautry27
    jautry27 Member
    Well, I was finally able to meet up with him so he could log it, but of course with my bad luck, I hit the biggest fucking raccoon on the planet, tear my CV boot, and fuck up my wheel bearing. Soooooo, with that said, I still can't get data logged, and I now get to put on a new CB axle and wheel bearing.
