Q: for SS (Close/open loop)
Discussion in 'Modifications & DIY how-to' started by goixiz, Sep 29, 2006.
  1. goixiz
    goixiz Active Member
    Besides mpg is there any major drawbacks to run open loop earlier ?
    Are there any redflags to getting into open loop sooner ?
  2. JJang12
    JJang12 Active Member
    I'm not SS, but here is what I learned. As long as your fuel table can make smooth transition (from 14.7:1 to your open-loop target AFR), everything will be good. When I'm 5th gear cruising on hwy, it runs in closed-loop. Whenever I apply partial throttle to speed up, it switches to open-loop (but still around 14.7:1 to 14:1) and waits for WOT.
    BTW, all the EM helps out to exit the close-loop sooner.
