My RPM does not increase (hence kinda bog down when accelerating). Is there an adjustment where i can increase the RPM a couple of hundred of RPM when the AC comes on. Is there even such an adjustment ?
You can use your cable and the ecuexplorer software to adjust the idle for ac on and off. To change the idle does not require a reflash so it will not mess with your cobb map. It is a realtime change that will get reset if you reset the ecu.
