Question about fuel pump install.
Discussion in 'Modifications & DIY how-to' started by justinxecushyn, May 15, 2010.
  1. I can't figure out if the green thing attached to the fuel pump should be removed or left there. it looks like a fuel pump reg or something but i'm not sure if its ok to say bye to it or leave it.
  2. Alex
    Photo?
  3. Here is a pic. Its that little green thing.
  4. 07Ltd#767
    If I remember correctly, when I changed mine over I only changed the pump and filter bag thing. Everything else that was there I left alone.
  5. wagunz_pwn
    Wirelessly posted (From Your Mom's House)
    it needs to be there.
  6. ok cool i left it there just wanted to make sure i was doing the right thing. its actually pretty quiet fuel pump. i had the same one in my integra and i could clearly hear it. i dont even know its there...
  7. Alex
    Which pump did you go with?
  8. walbro 255
  9. Alex
    Figured as much. Glad you got it all worked out sir!
  10. AutoxSTi
    AutoxSTi Member
    Where did you order you pump from?
  11. slowwrx
    Its a fuel pulse damner and it doesn't really matter if you leave it or not.
  12. MattBallRules
    MattBallRules Member
