Question about Headers
Discussion in 'Modifications & DIY how-to' started by sol drums, Mar 9, 2005.
  1. sol drums
    sol drums Active Member
    I bought my WRX heavily modded. It has 300whp. There is really nothing more to do to the engine that hasn't already been done. But it still has the stock headers.
    How much hp and or torque gain will I get if i put some new headers on? And is the gain worth the money?
    -drums
  2. miloman
    from what ive heard about headers... dont do it... the couple STi's with headers that scott has tuned made decent torque but low HP... plus ive also heard that replacing the stock headers will kill the boxer sound... im sure there are people out here much more knowledgeable than me and maybe they could give u some advice
  3. Alex
    Headers are not my speciality.
  4. Weapon
    I have the hks headers on my car and it gave me power throughout the powerband..seems to help the spool of my vf22 also..as far as the boxer sound..if you go with equal length headers you will lose a little bit of it..unequal headers though you still retain the boxer sound..hope this helps
  5. miloman
    thats good to know
  6. FTZ
    Not sure what Miranda has on her car, but her car no longer sounds like an STi.
  7. miloman
  8. yerrow
    yerrow Active Member
    hummers?
  9. BelvnAWD
    :eek:
  10. ScoobyMike
    ScoobyMike OG Mod
    :naughty:
  11. sol drums
    Well I have the APS SR40 turbo, I could always put in a larger turbo if I really wanted to. I was just thinking of how I can increase my HP and Torque. Not sure if I am really wanting to, just thinking of my options, that is if I have any.
    Weapon wrX, how much HP does you car have? Also how big is that vf22 turbo? Where abouts in Duluth are ya located? My address is Lawrenceville but I'm closer to Duluth.
    -drums
  12. Weapon
    im right off of satellite near SoG..as far as HP i would say im close to 300 at the wheels..not sure though..i need to get dyno'd..the vf22 is not a huge turbo but i have heard of people being able to hold 25lbs of boost to redline..it is quite a bit larger than the td04 though..i need to get a FMIC so i can get a more aggressive tune..but it is definately fast
  13. sol drums
    that's pretty close to me. if i come out the back of the subdivision there is old norcross, real close to boggs road. and it seems like our cars are almost twins. haha
    -drums
  14. miloman
    im curious to see how much power the vf22 makes at 3000rpm... even if its not peak power, i wanna see how the power of a vf22 at 3000 compares to the power of a td04 at 3000... so im curious to see ur dyno plot kris :D
  15. sol drums
    i don't know a lot about the dif. turbos, so i'm curious to see the dyno plot with my SR40. what's the dif. between the vf22 & the SR40?
    -drums
  16. Weapon
    APS SR30 turbocharger versus VF22 turbocharger air flow chart
    The above chart shows the highest performing VF Series turbocharger performance envelope inside that of the SR30 turbocharger (see through envelope). Whilst the SR30 offers similar air flow capacity to the VF22, the most striking fact is that the SR30 turbocharger provides a much wider operational range. What can't be seen in these charts is the fact that the SR30 offers higher durability than the VF22 particularly as the boost and air flow limits are approached.
    The chart below shows a clearer view of the inside of the SR30 and VF22 envelopes.
    here is a flow chart for the sr40
    now as you can see the chart shows that the sr40 should flow about 20% more air than the vf22 but i have read a few post where people dont see any significant difference other than build quality compared to the vf22 and ofcourse the price tag..i'd like to take a ride in yours to compare for myself though..
  17. sol drums
    thanks for the research!
    that's cool with me, i'm not going to be in town this weekend (i've prolly said this a million times on other treads so forgive me) but i will be at the dyno day next weekend.
    pm your phone number and maybe i'll stop by sometime since i don't live that far away.
    -drums
    "I've got a fever! And the only prescription, is more Cowbell!!" Hahahaha!!!
  18. sol drums
    I could just buy a CF hood and start the weight reduction!!
    -drums
  19. FTZ
    Carbon fiber hood is not really going to save you any weight, We have fiberglass hoods so you might save a pound if you are lucky.
  20. Weapon
    what he said...CF looks friggin sweet though!!.. hint: paint your sideskirts :hint
    also your turbo is cabable of running higher boost levels..that is a good way to make more power! how much boost are you running?
  21. sol drums
    All the pressure to paint my side skirts!!!! I... Don't know.... If..... Ahhhhhh!!!!:crying: :crying: :crying:
    I think I'm running @ 19... not quite sure.
    But all this will be fine, once I get her tuned!!!
    -drums
  22. ScoobyMike
    ScoobyMike OG Mod
    If you want to save a couple pounds, say 10 or so in the front end, get a performance battery. Couple of the guys at the dyno day had ultra lite batteries.
  23. sol drums
    Cool thanks, I had no clue about those!
    -drums
  24. Genya
    I have the DC Sports header on my car currently, and I like it alot, I will say the following:
    My EGT's settled down about 200-300deg less than normal.
    Still hits full boost
    Lag is more apparent, but makes it easier to drive day-to-day boost<good/bad I dunno>
    No drop in Boost still reaching target boost.
    Rips through the midrange, and top end much better than before.
    Sound=Different, but still boxery, they are unequal length.
    In areas where the car isnt in boost yet, the car strangely doesnt feel much slower.
    In short... Wish I had done sooner, price was right $330.00
    Havent driven the car for about 34 days, tilll this point in time where it was back together to check everything over, so Maybe it just feels faster than normal, however my friend agrees it rips harder than before by a long shot. Only power changes were fuel pump, and the header.
    Jason
  25. jasonhunt007
    jasonhunt007 New Member
    with new headers, you would not realize much in hp gain..spend you money on something else...
