Question
Discussion in 'Modifications & DIY how-to' started by lieutenant dan, May 15, 2009.
  1. lieutenant dan
    lieutenant dan New Member
    i have close to a $1,000 and i plan on getting the cobb accessport formy car. its an 02 wrx. i have turbo back exhaust catless and i have a check engine light. now i heard that i can get this tuner and get the stage 2 map and it will get rid of the code and give me more power. is this true?
    also i heard that topspeed and batle grounds are good places to go. i've been to topspeed and checked them out and they seem like they know what their doing. is that the best place to go, and do i need to just bring them the tuner and my car or do i need to download the map first?
    thanks.
  2. flat4ever666
    flat4ever666 Member
    Topspeed...done.
  3. yerrow
    yerrow Active Member
    You can download the ots map over there and then get protuned
  4. FTZ
    Yes, most likely, reflashing the ECU will clear/hide the CEL.
  5. ScoobyMike
    ScoobyMike OG Mod
    Topspeed ftw
  6. ZenMotors
    ZenMotors Member
    If you are looking for an Cobb AP let me know. It will be worth your while. Also you should check out Mike Sargent for tuning as well.
    Take care!
  7. integroid
    Take it to topspeed and get them to pro tune it with the Cobb APV2
  8. SonicBoom
    SonicBoom Active Member
    Just an FYI, you don't have to get tuned to use the AP stg. 2... It will clear your codes and give more power. Installation/downloading the maps is really easy. Don't get me wrong, a protune is a great idea, it just not a 100% necessary depending on your needs.
  9. Strayen
    Strayen Active Member
    And since you have an 02 wrx, you still have your stock uppipe or an sti or some other catless uppipe? Just make sure that's catless before using stg2. I think stg1 will work with the stock uppipe.
  10. lieutenant dan
    thanks for all the info and when ever i get the tuner and program it i plan on dyno it and see what HP i have and i post it up when i get it done. thanks again.
  11. Jake
    yes get a catless up pipe first then go GET IT TUNED!
  12. siegelracing
    We'll match any offer you get AND if you buy the AP from us you get a half hour of free tuning :D
    Siegel
  13. lieutenant dan
    well i have all ready ordered the AP. now i just got to figure out how much it will cost me on getting topspeed to tune it for me.
  14. Sparta
  15. Jake
    figure at least a couple hours. Bring more money than you think you'll need.
  16. lieutenant dan
    is it 160 for one hour
  17. wagunz_pwn
    plus the $45 for dyno and shop fees.
  18. lieutenant dan
    so im looking at about $400
  19. Jake
    ~ish
  20. lieutenant dan
    well i rounded up a smidget.
  21. wagunz_pwn
    i'd bring a little extra...never know.
  22. 07Ltd#767
    i'm budgeting twice that for my tune...
  23. Mike@TTR
    Mike@TTR Active Member
    Your tune will most likely be a little more complex given the rotated kit and all ;) Or just put on the APv2 and save the pro tune for when you are finished modding it.
  24. Sparta
    X2, I'd just run the map for stage 2 that comes with the accessport and then when you mod later, (I.e intake, intercooler upgrade) etc you can get protuned.
  25. FACE
    just make sure you get a catless uppipe!
    TopSpeed FTW! :wiggle:
  26. undrgrndrdr15
    undrgrndrdr15 Active Member
    i would just use stage one unless you change your up pipe to catless... once you have the up pipe then go stage 2 until you feel the itch to need more and then i would go for a protune... mike sargent is a great guy and can help you out with anything you need!
