Need warenty work done and I need to know if the ecu records boost levels or anything that a mbc might change thanks- Chris
Thanks again for the reply. I was hopping that it is not logged. So you say to go to Subaru of Gwen.? Are they picky about warrenty because there is also a down pipe and exhaust on there thanks. chris
like i said... if anyone will do it under warranty, it will be them... if they can't warranty it, nobody else will... they're the coolest subaru dealership in the area
it doesn't record anything other than a "snapshot" when a CEL happens. If there aren't any CEL's, there aren't any records. What kind of waranty work do you need done? If it doesn't have anything to do with running high boost, it won't matter. If it's a Subaru defect, we can likely fix it under waranty, if it's not, we shouldn't ask to. Siegel
Hey man, I got your phone call this morning. I was pretty busy so sorry I couldn't answer. About the logged boost levels. I'm pretty sure that it doesn't log them, but I would def call SoG and ask for Scott he would probably know.
hey scott thank you for talking with me about this matter. I will be up to subaru tomrrow. I am going to try to meet up with you guys at NP if I can get the car going thanks- chris
