quick question about dp install
Discussion in 'Modifications & DIY how-to' started by crash#2, Feb 17, 2006.
  1. crash#2
    crash#2 Member
    has anyone else had trouble remove the bell mouth bolts. they are sticking for me. i havent tried any aerosol sprays or anything yet just wondering. i ran out of time today and had to take my girlfriends bike to work. getting up at 5 am to try again.
  2. scuby drew
    scuby drew techos ftws!!EEEE
    i had a little bit of a problem on my current wrx with them, just sray any kinda aerosol on them and they will come right off, you can almost watch the color change from the musty brownish back to a lighter color then they will come right off
  3. UBAR
    UBAR Member
    Yep WD-40
  4. jt money
    like they said a few coats of any aerosol lubracant will do. those bolts swell and shrink so much that they get tight. bottom one closest to the drivers side is a real nuckle buster!
  5. crash#2
    crash#2 Member
    very much appreciated guys, thank you
  6. moose
    PB Blaster is pretty awesome for this. Also, leverage is your friend -- use it if you have room!
  7. bassplayer
    bassplayer Member
    when installing my dp i couldnt get the stocker off. i was on a step stool literally kicking the wrench while my friend held it on the bolt. needless to say i have a couple dents in my passenger fender after that install. btw, the kicking didnt work.
  8. pEd
    PB Blaster...
    it's a suby's second best friend.
    soak it and let them sit for a little while
  9. Weapon
    yea I dont do any install without PB Blaster
  10. Alex
    Your problem is that you are spraying with the aersol, you must soak on the subarus :)
  11. sol drums
    sol drums Active Member
    :werd: that is soooooooo true!
  12. clemsonscooby
    clemsonscooby Active Member
    Invest in a cheater bar and a decent pipe to hook it to. Just make sure you get them down tight, they will back off.
  13. moose
    My advice would be to torque 'em to spec... they won't back off and you also won't overtighten and cause leaks.
  14. clemsonscooby
    If your dp has a divorced waste gate pipe some of the bolts on the bottom are unreachable with a torque wrench. You have to use a simple open ended wrench, so its difficult to torque to spec. You can use some loctite, but the temps are normally way to high for them to be effective.
  15. lostinthewoods
    Get the DP on ok?
  16. crash#2
    crash#2 Member
    yes long ago ( about an hour after the first reply)
  17. +1 for PB Blaster!
    How's the Helix working for ya?
  18. crash#2
    crash#2 Member
    the pipe is a dream
    (small crack in the resonator, fixed tommorow)
