Quick Question about struts
Discussion in 'Modifications & DIY how-to' started by Goose013, Jun 27, 2006.
  1. Goose013
    Goose013 Member
    will stock 03 WRX struts fit a 93' Impreza using their tophats?
  2. clemsonscooby
    clemsonscooby Active Member
    You might want to contact KYB for that question. I am not sure many people have actually done something like that. I spoke to them once and they were pretty helpful when I had some questions. Otherwise, if someone doesn't chime in, you can figure it out the hardway by determing the suspension geometrys and loads, but that would suck.
  3. jt money
    i want to say the fronts will fit but not the back. genya just added some 02 shocks to his 94 L and they wouldnt fit correctly. i would wait for a stronger source than me to chime in though.
  4. Goose013
    Goose013 Member
    thanks, I asked uncle scotty on nasioc and he said they are the wrong length; so they may fit but definitely not correctly
  5. Alex
    Why not just try it and find out then ?
  6. GTscoob
    WRX wagon front struts would work better, they use the same track as the older Imprezas. I think the rears are all pretty compatible as long as you have strut tops that match the springs and struts.
  7. Goose013
    Goose013 Member
    'cause the guy is in CT and unless you have a 93' Impreza around here it would be mighty hard to do ;)
  8. SkullWRX
    SkullWRX Member
    Bobby is right. older impreza and wagon fronts are interchangable, but the rears are the problem. Why not just use dedicated 93 struts?
  9. Goose013
    Goose013 Member
    guys....I have my struts for sale and a potential buyer just asked me if they would fit a 93', it was supposed to be a simple question. He was looking for a cheap upgrade I'm sure.
  10. GTscoob
    On our cars the rears are all the same wagon/sedan. I dont know about with the previous generation.
  11. calmnothing
    I know that STI Ver7(04) struts would fit aslong as you use RS/L springs and their appropriate tophats.
    BTW anyone have any STI Ver7 struts for sale?
