rear deck install?
Discussion in 'Modifications & DIY how-to' started by Mad Mallard, Apr 2, 2007.
  1. Mad Mallard
    Mad Mallard the mad mallard
    anyone installed speakers on their rear deck?
  2. FTZ
    Not 100% sure, but I believe there is Metal under the rear dash plastic. I don't believe there is an opening for a speaker there, but I may be wrong. If there is an opening, then to install speakers there would not be overly difficult. It would require cutting the plastic cover a little to allow a speaker to sit in there, but again, nothing overly difficult. If you are interested in doing it, I can definitely do this kind of install, assuming I don't have to cut thru metal to make a hole for a speaker.
  3. Intrigue2727
    Intrigue2727 Member
    my 05 has holes for the speaker, but one of them has some relay box for something.
  4. Jake
    all wrx's as far as i know have an area in the metal that are sufficient for speakers. i forget who it was i saw, but recently i saw someone with 6x9's installed. I just remembered i have a decent set of 6x9's that i might want to install....
  5. AirMax95
    AirMax95 Active Member
    We can always try, I have a knife:naughty:
  6. Jake
    anyone else with more info on this install. I think I am gonna try this when i get my car back. But how and where do i extend the speaker wire from?
  7. Mad Mallard
    from another amp, preferrably. ;p
  8. Jake
    so maybe i should wait until i get an aftermarket head unit?
  9. Mad Mallard
    well, lemme clarify, are you going to get rid of the rear door speakers?
  10. Jake
    no, keep them, just add 2 more and upgrade the rest probly.
  11. Mad Mallard
    okay, well, a head unit is only gonna have connections for two pairs.
    if you want three pairs, you're gonna need another amp.
    what do you have now? Stock?
  12. Jake
    yep, stock
  13. Goose013
    Goose013 Member
    get you a high-low line output converter and a 4 chanel amp and you can run 3 sets. 1 pair off your stock radio then 2 pair from the amp or there are several other combos you could run
  14. Mad Mallard
    yeah, but thats alot of wiring. You'd ideally want your best amp powering the speakers you hear the most, right?
    Wouldn't you just amp everything if you had the space?
  15. FTZ
    My Suggestion would be to drop the rear door speakers. Unless you have people that ride in the back, you are not hearing the rear door speakers anyways. The imaging is completely off to be able to hear them in the front of the car. The rear deck will fire sound up into the rear window glass, and will then be redirected to the front of the car. It won't be perfect, but much better than the rear door speakers.
  16. Mad Mallard
    i just took a look, and there's a chance of interference with the trunk's springbar...
  17. EJRex
    EJRex Member
    If you wanted to keep the rear door speakers and didn't want to run an amp, you can tap into the speaker wires in the harness before the doors, run you some wire to the rear deck, and just run the speakers in a series, instead of parallel so you don't change the ohm load. It would be a little less power to each speaker, but you'd have 6 vs 4. Your call... speakers in the rear deck are doable with some cutting.
  18. Jake
    Yeah tj the ones I saw installed had a spacer to raise the speakers up, and avoid those springs. And yeah I have zero dollars so this is gonna be on the back burner for a while.
  19. Silver Surfer
    Silver Surfer Member
    Anyone had any luck on this project?
  20. Mad Mallard
    i thought about this some more. You mean spacers on top of the rear deck, not underneath, right?
