Recommendation time!
Discussion in 'Modifications & DIY how-to' started by XanRules, May 14, 2008.
  1. XanRules
    XanRules Active Member
    2 things, really. As always. :D
    1. What's going to be cheaper, a full rear disc conversion (junkyard parts) + new pads or getting my drums redone?
    2. Front pads are squealing, probably almost gone. Recommendations for replacements?
  2. Galimore
    Galimore Member
    I put on EBC Greenstuff pads - they were pretty cheap and stop a lot better than the stockers but make a ton of dust ;). Also they are silent, which is a benefit. When I replace these I'm going to try Hawk HP's to see how they compare.
  3. calmnothing
    Rear disc conversion can be expensive.
  4. XanRules
    assuming I can get it done for $150 or less?
  5. seanwrxwagon
    seanwrxwagon Member
    HP+ pads for the front IMO. If you can convert to rear discs for that price I think it would be a no brainer. I'm not sure how that would affect your brake bias though.
  6. calmnothing
    Not with new pads and rotors you can't. $150 is usually for used and worn parts. Check the rs forums because you may never know.
  7. XanRules
    There was a setup for sale on Nasioc, $200 shipped. New stuff. Lemme see if I can find it.
    What's everyone else think about the HP+ pads?
  8. Sparta
    Depends what you want to do.... unless you don't do mountain runs or autox *often* I wouldn't get them simply because of the expense and squeel whenever you come to a stop.
    But, if you need a performance brake pad, they are the way to go.
  9. Galimore
    Galimore Member
    Yea the HP+'s are notorious for being loud, that's why I'd stick with the regular HP's unless you are doing very aggressive/competition driving regularly.
  10. XanRules
    Alright...regular Hawk HPs?
