Red Dash
Discussion in 'Modifications & DIY how-to' started by Greg, Oct 31, 2006.
  1. Greg
    Greg Active Member
    What is involved in making the HVAC lights red, bulb condoms or LED replacement? I have a double DIN TV, so I just need the three red knobs to be red. Its an 06' by the way
  2. Demo24
    Demo24 Member
  3. Greg
    Greg Active Member
    Cool man, thanks. So it is just the bulb condoms for the HVAC?
  4. crashtke
    There are also replacement LED's that supposedly look better and are a bit brighter. Will look for a link....there is a link to it in one of the gauge threads.
  5. crashtke
  6. nsvwrx
    nsvwrx Active Member
    he said condom =P
  7. Greg
    Greg Active Member
    Hey crash, that guy to talked to the other day with the wrb/gold, he does work with me.
  8. crashtke
    Did not know you as Greg, hehe, the James kinda sticks out more. He was a nice guy though. We sat and talked as long as was practical since I was working.
  9. Alex
    I vaguely remember that it might be a slightly different process for the new center console. I have not taken one apart so I cannot really say. Good luck though.
  10. Greg
    Greg Active Member
    Hey Alex, thats another mod you can add to your vendor account...
  11. Alex
    I was considering it actually. I can look around and we can try and do your hvac if you'd like :)
  12. gte123v
    gte123v Member
    condoms won't work, the LED's in the HVAC are imbedded and very small, if you even put some sort of red film over it, it will not be bright enough to penetrate the green film on the knobs. You will have to solder in new red LEDs, and it will be a pain just b/c there's barely any room in there. You'll definitely have to use the dremel to the max to make some room.
  13. Alex
    Sounds like a challenge!
  14. Greg
    Greg Active Member
    I got a pencil grinder if you want to try it Alex :)
  15. gte123v
    gte123v Member
    definitely was. It took me a good 2-3 hours just to put in 3 LEDs.
  16. Alex
    Perhaps :sx:
  17. Greg
    Greg Active Member
    I usually free on the weekend, exept this one. I'm doing that car show Sat. and the mountain run Sun.
