Rediness Fail
Discussion in 'Modifications & DIY how-to' started by WRXCoupe, Jul 24, 2009.
  1. WRXCoupe
    WRXCoupe Active Member
    Another victim of reediness fail, seems like an issue sometimes with modded Suby's. Battery was disconnected about a month ago for a grounding kit. Brandon at AllPro hooked me up to their scan tool yesterday (Big props to AllPro for helping hand), results were readiness fail evap emissions and 02 sensor. I checked with Scott even though I am tuned should not effect readiness. Brandon and I tried the recommended Suby fix: drive for 10 miles between 47 and 53 mph power off restart the car and do it again to no avail. Any suggestions are much appreciated my time is up 8/1/09 and I cannot get a ticket for this.
    Thanks
    Mike
  2. Kokopelli
    there is a way to reflash the ecu to force the readiness monitors to be on immediately after an ecu reset.
  3. siegelracing
    That's true, but only with OS. I suppose he could un-marry, open-source, go pass, re-marry....
    Siegel
  4. WRXCoupe
    Just to make sure I interpreted this correctly: I need someone with OS, take my car to them, un-marry AP?/ecu, hook up to open source and force the codes and a limp mode tune, then pass emissions and marry back to AP? Would this require a OS tune or simply a quick flash.
    Then the obvious question who could do this and what would they charge?
    Thanks
  5. Matt
    Is your birthday in July or August?
  6. WRXCoupe
    8/1/09
  7. FTZ
    My registration does not line up with my Birthday in any way. I had to get my registration renewed before the end of June, but my birthday is in September.
  8. Matt
    generally, you have until the END of the month to get it taken care of.
  9. Matt
    how the hell does that pan out? Are you the only one the lien/title is registered to? GA has registrations done according to birthdays
