redline tranny fluid
Discussion in 'Modifications & DIY how-to' started by bigb996, Jan 25, 2006.
  1. bigb996
    i have been doing a lot of reading latly and from what i have read redline is the way to go. I have a nasty grind when i shift to 4th gear and it happens everyday i drive the car. It will either scratch, or grind and it only does it at high rpms and quick shifts. I have royal purple now and i think that may be causing some of hte problems.
    well after reading i have read that if i do redline shockproof it should eliminate this problem for the most part. My question is what should i do; lightweight, the middle grade, or heavy? also can you fill a tranny and diff with shockproof? or do i need to do a cocktail style?
  2. wrxguy
    wrxguy Member
    omg get off royal purple now. That is worst stuff for your tranny. I'm running redline shockproof right now and its the best stuff out there! Right now im running heavy in mine . Yes you can fill your diff with shockproof!
  3. Genya
    Hmmm Ive heard a lot of varying opinions, on this. I have run synchomesh instead of shockproof and had good results on that, but never tried the shockproof combo. After my clutch change, whatever fluid was placed in the car eliminated all grinds that I had and other issues(with a lil synchomesh for good measure). Gotta go ask what that was. Give Uncle Scotty's tm* mix a try or go stock and change every 20k.
  4. bigb996
    i ordered 5 qts of heavy just now, i hoep this will fix my problem. thanks guys!
  5. Alex
    If you dont mind me asking, what were you paying / qt ?
  6. bigb996
    i got 5 qts for 53.00 shipped. they are 8.50 a qt at www.titanmotorsports.com. anyone know how long it takes to change this fluid out?
  7. wrxguy
    wrxguy Member
    Redline is thick and going to take a long time if you dont have a funnel. i think 1 hour to drain and fill.
  8. bigb996
    i will be sure and post after i put the stuff in and let yall know how it is.
  9. gomikeyp
    gomikeyp Member
    i have redline 75w90ns in my tranny and started grinding 5th gear after that... suckie...
  10. wrxguy
    wrxguy Member
    Then i dont think that has anything to do with the redline. do you know if it pops out of when backing out if so then i would recommend going to a trannsmission shop to have it inspected. Trust me im on my third transmission
  11. gomikeyp
    gomikeyp Member
    wrxguy, if you are talkin to me, no it doesn't pop out of gear when I'm going reverse.
    I really doubt that my tranny is going bad since I've never drag raced and launched my car 2-3 times after purchasing the car lol.
    I had this happen with crap tranny oil though. My prelude started grinding 5th when I got the 5spd swap done and I didn't have any gear oil at the time so used synthetic motor oil. After replacing with Honda fluid, it went away.
    I've read other people having problems with grinding gears with Redline NS on Nasioc so I'm hoping there's nothing wrong with the tranny. ;)
  12. sol drums
    sol drums Active Member
    I put Uncle Scotty cocktail in my tranny when fixing the clutch. I'll let you guys know what i think when i start diving it again.
    I know other on here have tried it and seem to like it alot.
