roof rail help
Discussion in 'Modifications & DIY how-to' started by Vektra, May 5, 2008.
  1. Vektra
    Vektra Member
    quick question. I was going to buy these for my 02 wagon but they are off of an 06 saab. I didn't think there would be a problem but I want to double check before I drop the cash
    Saab92x.com / FS: Roof Deletes
  2. GTscoob
    Yeah, you'll need some expansion nuts to fill the holes in your roof when you pull the rails off though. You can get the blocking plates from a saab dealership for ~$10 a piece (need 4), or get a box of expansion nuts for $3.
    I've got a nice writeup on here for swapping roof rails from when I did it a while back. Its easy and completely transforms the look of the wagon.
  3. Vektra
    Vektra Member
    are the blocking plates that much better? this is the first I have heard of them everyone else just says use the nuts. also do I really need to go ahead and order all the clips suggested? its about $35 worth.
  4. GTscoob
    Blocking plates do the exact same thing. Honestly if you dont have them just go with the locking nuts, but if you're doing a direct swap with a 9-2X he'll have no more use for the plates so you can take them.
    You dont need an entire set of clips but get at least 5 because you will end up breaking a few popping off the old trim.
  5. GTscoob
  6. Vektra
    Vektra Member
    thanks man this will be a great help. I think this write up is what got me looking at doing the swap again.
