scangauge II - group buy
Discussion in 'Modifications & DIY how-to' started by goixiz, Sep 6, 2007.
  1. goixiz
    goixiz Active Member
    Are you guys insterested in a group buy for the scangauge II
    http://www.scangauge.com/
    If interested please reply
    Savings $ is fairly significant
  2. socrates42
    socrates42 Member
    does it do boost, and EGT?
  3. goixiz
    yes boost and also IAT (no EGT)
    The stock EGT is useless anyways because its so far from the manifold
    What is most interesting its Open loop close loop
  4. lostinthewoods
    uses your ODBII port... hmmm Interesting little invention, but No Soup for me..
    ps: adam - subaru challenge :)
  5. GTscoob
    Seems like for just a little bit more getting an Ecutek or PSI3 data monitor is a much better deal as you can hook aftermarket sensors up to each of them in addition to monitoring all of the standard OBDII sensors.
  6. goixiz
    Interesting ! How much is a PSI3 ? Who makes it and where are they located ?
  7. Alex
    cool little tool :)
  8. GTscoob
    I'm pretty sure that they arent making any more, I think I remember hearing something about the company going bankrupt but its the exact same as an Ecutek data monitor and can be found used for around $300. Instead of a white face with black buttons you get a black face with blue buttons and there were some different options for the display screen.
  9. pEd
    Ming, I've got one if you want to check it out.
    I've been half tempted to replace it with gauges.
  10. goixiz
    Thanks pEd but i like the stealth mode
    I may when things calm down
  11. Alex
    Gauges are fun :)
  12. WJM
    how much savings are we talking here...
  13. WJM
    $159 on ebay instead of $169 on the site.
  14. Cool_____
    My buddy has something like this in his LS1 powered RX7 FC. It is one gauge that flips through multiple settings. Pretty sweet.
