Scary hood release at high speed
Discussion in 'Modifications & DIY how-to' started by blaster, Feb 18, 2010.
  1. blaster
    On the way to Mardi Gras, I noticed a very strange and scary phenomenon – when approaching triple-digit speeds, my hood pops, as if I've pulled the hood release lever. It's still secure, but scary as Hell.
    Anybody got any ideas as to why this may happen, and more important, how to make it stop happening? And don't tell me not to drive that fast. I know.
  2. Alex
    Maybe you didnt close it? :eek:
  3. blaster
    Nope, it was totally closed. Slammed shut after the first time it happened. Didn't solve anything.
  4. Weapon
    maybe its a sign
  5. Matt
    found the 'problem'
  6. Alex
    Maybe you need a giant mercedes emblem on the hood?
  7. Doug@DBW Motorsports
    the latch needs to be adjusted
  8. triple digits on the way to mardi gras? I must have seen atleast a 100 cops on the way there and back this year. especially in Mississippi
  9. blaster
    Suggestions on how to do that?
    There were a ton in Alabama, but mostly just yesterday. Where I was doing this was a very wide open and empty area, with lots of clear visibility. I wouldn't be doing that speed otherwise.
  10. integroid
    Obviously take it to someone that knows how to do it since you do not know:)
  11. blaster
    Good point.
    Anybody have any idea why this would only happen at high speed?
  12. WJM
  13. TOI
    TOI Member
    time for hood pins?
  14. slowwrx
    Its probably Bar Karma coming back to haunt you since you refused Justins shot......
  15. blaster
    I told him long before we got there that I didn't want that car bomb. He didn't have to order it.
    FYI, not drinking for Lent. That means that Justin should continue not buying me drinks.
  16. slowwrx
    Well Jesus loves you but Justin thinks your being a bitch
  17. 07Ltd#767
    lawl...alcohol makes baby jesus cry
  18. Jake
    jesus turned water into wine....
  19. blaster
    It has nothing to do with me emulating Christ, and I much more about laying off after Mardi Gras. It's a test of willpower.
    Back on point, anyone have any ideas why speed would be causing this problem? Or suggestions on which way (I can figure out the how) I should adjust my latch.
  20. nicad
    spend about 5 seconds looking at the latch and you can probably figure it out
  21. Trey
    Trey Active Member
    Exactly...if the latch is not adjusted correctly, and the rubber adjusters on the side as well, then it will have play.
  22. dundunskeert
    dundunskeert Member
    Air gets trapped under the hood and pushes the hood up..
    Use duct tape.
  23. vegasbomber
    vegasbomber New Member
    ahhaha duct tape... this has happend to me but i was approching 80 miles per hour only, not tripple digits, but then i was like oh oo... then boom hood slamed into my windshild, and i was driving huntched over to see where i was then pulled over.. man scarriness.... i would say time for hoodpins also...
  24. blaster
    Duct tape, hood pins, not helping.
    Me and some other guys put our heads together and came up with putting washers on the hood latch to force it closed a little more. Seems to be working, but if anybody has any other helpful suggestions I'm open to hearing them, since this thread is back from the dead and all.
  25. RSConvert
    Does the hood move when it is closed? Possibly your bump stops?
    Come to Allpro, we have a latch off an 06.
  26. blaster
    It doesn't move, and it doesn't do anything when I try and pull it open when it's fully latched. Actually that picks up the front of the car a bit. Can I have you guys look at it at the install day, maybe? It hasn't popped up since I tried the washer thing, but I haven't spent much time near triple digit speeds, either. It does wobble at speed, but aluminum + hood scoop + bumpy highway might explain that.
  27. RSConvert
    Sure thing.
  28. C_wagginz
    Mine used to do that...then I found there was missing bolt for the latch mech....
  29. blaster
    Hmm. That'd be worth looking into.
