seat cushions
Discussion in 'Modifications & DIY how-to' started by ninja01, May 7, 2011.
  1. ninja01
    ninja01 Member
    Does anyone have a front set of bottom gray seat cushions for an 01 forester L for sale or know where I can get a set somewhat cheap? The drivers side cushion is worn out and I want to replace it so I figured id just get both of the fronts. Thanks
  2. b reel
    try pullapart or call LKQ
  3. ninja01
    ninja01 Member
    hmm I checked the pullapart website for the one up this way and all they had was an Outback at the time but ill check again
  4. cMags
    cMags Member
    Who is lkq? Also does anyone know what seats are bolt-in compatible with an '01 foz? Impreza, legacy, outback? I ask because I'll likely be drafted for this project... :|
    Sent from my LS670 using Tapatalk
  5. Allpro Subaru
    Allpro Subaru Registered Vendor Supporting Member
    Impreza def...Legacy most likely will bolt in.
  6. Matt
    impreza, legacy, forester, etc...they're all the same. bracket with a different looking seat. Hell, seats up to at least 07 will fit in this car. I'm not sure if the new seats will have the same brackets.
    I'd look for some bugeye RS seats or something. those will have the better bolstering (of the USDM models) and no airbags to worry about.
  7. b reel
    LKQ is one of the largest auto salvage companies, have a couple of locations around here.
