security system HELP
Discussion in 'Modifications & DIY how-to' started by rolling_trip, Jun 15, 2005.
  1. rolling_trip
    rolling_trip Active Member
    I just Installed a turbo timer, which works awesome. However the security system that i have has an auto lock feature, which when ever the car is started the door locks and when it is turn off the doors unlock, hence my problem. anyone here ever install a security system before? I had the dealership put it inbefor i bought the car, which in turn they paid someone to install it. the dealership has no idea who installed it and i have no paper work on it. HELP :wtc:
  2. FTZ
    So you can't unlock the doors with the key fob when the car is running? I know there is a fix for a turbo timer and factory alarm, but I think that one doesn't let you arm the car with the engine running. Can you disconnect the AutoLock Feature. It is actually a bad feature to have. If you ever get into and accident and get knocked unconcious, they will have to smash your window or pry the door open.
  3. rolling_trip
    u can unlock the doors with the car running, but when u take out the key, get out, lock the car, after the turbo timer takes control and shuts the car off, the doors unlock
    i want to disable the auto lock feature just not sure how, i found the control box but havent found a name, and there are BUNCH of wires coming out of the box
  4. Alex
    I dont really know all that much about them, wish I did. If it helps, I did find that feature somewhat annoying when we were doing the road tuning in yeh car heh.
    best of luck with the issue!
  5. jt money
