should i start saving for a clutch
Discussion in 'Modifications & DIY how-to' started by awdlaunch132, Sep 4, 2008.
  1. awdlaunch132
    awdlaunch132 Member
    so long story short i pulled into a pretty busy intersection about 3 days ago and really had to get on it through first and second so i wouldn't cut anyone off. I had the clutch smell for a minute or two and thought everything was fine but since then every once in a while, especially when starting from a stop, i get the clutch smell again (it probably happened five times since the first time). car doesn't feel slower or pedal fell isn't any different at all just a smelly clutch on occasion. is this a sign that the clutch may be on its way out or did i just glaze the clutch and that is what i am smelling.
  2. Davidwrx
    Davidwrx Member
    You get the clutch smell when you let it slip too much during engagement. It doesn't necessairly mean your clutch is toast, it just means you took a little bit off of its life.
    You have a problem when you are in gear, clutch pedal out and it starts to slip (engine revs, but car isn't moving). Happens typically under heavy accelleration or upper gears.
  3. awdlaunch132
    awdlaunch132 Member
    ya i let the clutch slip i too much the other day and expected the clutch smell i just didn't think it would keep coming back...the clutch doesn't slip or feel any different with the engagement so the more i think about it the more i think i am fine.
  4. Jake
    how many miles are on it? if you get 60k-75k out of it you're either super lucky or a super old man
  5. integroid
    ^^LOL^^
    I have gotten 40K out of mine and 10K of that was with my bigger turbo....My clutch has started slipping so I am off to find someone to install it.
  6. wrxin8or
    Mine has 93k on it, and no slipping at all...
  7. Jake
    just depends on the driver
  8. Berzerklo
    Berzerklo Active Member
    Yeah I have 80k on mine, and as far as I know I have the original clutch.
  9. AirMax95
    AirMax95 Active Member
    I have 105k on mines, lol. No slip all grip!
  10. Jake
    but we all know you drive like a grandma!
  11. WRXCoupe
    WRXCoupe Active Member
    70k and I'm old:eek3: Only my foot slips now and then.
  12. AirMax95
    Lol, yep, cause right now if it pops I can't guarantee that I will fix it, lol.
  13. awdlaunch132
    awdlaunch132 Member
    it just rolled over 60k i am pretty surprised it has lasted this long since i don't exactly baby the car at all (i tend to have a heavy foot). although it is pretty much stock so i think that has helped.. no real power mods on it any way.
  14. techlord
    terrance and brett both drive like my grandma.
    But to answer your question I start saving for something as soon as I have exasperated the current pile of loot.
  15. bomjoon
    bomjoon Active Member
    you should save up $$ for mods period. regardless of whether its a clutch or not. :p
  16. wrxin8or
    :unamused:
    just because my car has no power mods (for now:squint:) doesnt mean I drive like a grandma
    my car does have quite a few suspension mods, and handles quite well
  17. 07Ltd#767
    different car, but my last mustang had ~120k on the factory clutch...and I'm pretty sure I launched that thing more / harder than I ever have the STi.
    Donuts are fun :D
