Show off your Set-up!
Discussion in 'Modifications & DIY how-to' started by G-WRX, Aug 18, 2011.
  1. G-WRX
    G-WRX Member
    I saw a thread on NASIOC like this. So I figured why not get one started on WRXATL? Post a pic and a description of your ride's wheel/suspension set-up!
    For Go, or for Show!
    Maybe something like:
    Rims: Brand, Size
    Tires: Brand, Size
    Springs/Struts: Brand, Current Adjustments
    etc.
    Maybe a little comment on how your vehicle handles and how satisfied you are with the setting.
  2. Raziel1
    Raziel1 Member
    Patiently waits to see josh booth's specs
  3. josh booth
    josh booth Active Member
    17X9 +30 Privat Rember's
    235/40/17 NITTO NT05
    JIC FLT-A2 coilovers
    With changes to come soon.... ; )
  4. josh booth
    Know one else is willing to post there Set-up.....
  5. superdoughboy4
    Yours blows everybody's out of the water. There's no point anymore.
  6. bixs
    bixs Supporting Member
    The title "Show off" kinda deters me, I like functional to what I need at the moment and think is necessary.
    18x8.5 Stock BBS
    245/40/18 Goodyear F1 A/S UHP
    RCE Yellows (25mmF/22mmR perrin bars on stiffest)
    Fast enough to be enjoyable. Great feel on the daily drive.
  7. superdoughboy4
    Let me drive it once and I'll decide that. :sx:
  8. WRXbryanATL
    WRXbryanATL Member
    if josh's wheels were 5x114 id probably be all over buying them.. autox has a pair on nasioc for sale right now im contemplating
  9. Matt
    IIRC, his were dual drilled.
  10. rsutton1223
    I'll play even though it is nothing really special.
    Rims: XXR 527 Flat Black 18x8.75
    Tires: Hankook Ventus V12 255/35
    Springs/Struts: Currently stock with a kick ass alignment from AllPro. Contemplating the Bilstein/RCE combo currently. Lowers 15mm but more about function than stance.
  11. bixs
    Let me take you for a drive and let you decide, nice try
    Plan on washing/waxing it this weekend, I'll take a pic. Lowers only slightly, but enough for people to look at it and realize it is not stock. BTW like the edit to the first post
  12. G-WRX
    G-WRX Member
    WRX3 by G-WRX, on Flickr
    Prodrive Springs on Stock Struts
    Cobb Rear Sway Bar (don't know the diameter)
    Rota Tarmac 1's Powdercoated Black 17x7.5 5x100
    Bridgestone Potenza 245/45/17
    Comments: The rear sway bar makes the car so much more responsive. I plan on putting a FSB on sometime soon.
    As far as the spring/strut combo. It's a nice ride. Not stiff, but still has performance benefits. I am replacing these
    with BC coilovers soon. As far as the Bridgestone Potenzas, amazing tires. They are quite expensive, but they ride
    extremely well. I would say that this is easily the best set of tires I've had.
  13. C_wagginz
    Rims: Rota Torques 17/7.5/48
    Tires: Yokohama Avid W4s 225/45/17
    Springs/Struts: Epic Engineering Springs (1.25" measured drop), stock struts
  14. techlord
    no full pics as I can't get the car out of the garage.
    XXR 522 Flat Black 18"X9" +38
    Advan Neova AD07 265/35/18
    TEIN Flex CO's with EDFC
  15. G-WRX
    G-WRX Member
    ^^^ Good God that looks soo much better!!! GJ BRO.
  16. G-WRX
    G-WRX Member
    You guys Scared to post your rides????
  17. jchon3
    jchon3 Supporting Member
    yes....
  18. josh booth
    G-WRX post your set up....
  19. b reel
  20. josh booth
    ^^ I recall seeing that truck in that shop where I pickup that turbo from you.
  21. b reel
    sitting at home with a blown trans and some minor electrical issues. Sounds nice at idle with a little whine under the hood. LOL
  22. wagunz_pwn
    Rims: Factory 4.8 x 10"
    Tires: BF Goodrich Silvertowns
    Springs: Koni struts w/ custom 1" Swift coil springs
  23. b reel
    here's the other ride, just as dead
  24. yerrow
    yerrow Active Member
    18-7.5 +48-ish Volk TE37
    225/40/18 Nitto something or another
    tein shitty techs on tokico d-specs. not too shabby of a ride even though the s-techs are way soft.
    i still need to install the bc coilovers i bought from brandon...last summer
    18-8.5 +46 with a 3mm spacer 5zigen 520's
    245-45-18 hancook s1 evo
    swift springs on stock struts
    way too soft of a spring rate, it scrubs the inner tire side on hard compressions.
    eventually if i ever get around to installing the bc's on the blue wagon, the fozzy will get the d-specs
  25. G-WRX
    G-WRX Member
    ^^----:wiggle: Will take some pics this weekend! Got a spot reserved on this thread for it as well... And then I will post em up with the BC's
  26. b reel
    when you doing the Busa swap?
  27. wagunz_pwn
    as soon as that Porsche is on the track...
  28. b reel
    Porsche, learn to spell check
    it's the least of my concerns right now, it will continue to sit with silica-gel dry packs collecting dust
  29. RoMe
    RoMe Active Member
    Rims: 17x9 +45 5zigen fn01r's
    Tires: 245/40 bfgoodrich kdw 2's
    Springs/Struts: BC Coilovers
    Rims: 2006 WRX wheels
    Tires: 215/45/17 Khumo Ecsta's
    Springs/Struts: Whiteline springs custom blown struts
  30. wagunz_pwn
    Fixed...it was early and I was spacing out in a meeting.
  31. nik_05STi
    nik_05STi Member
    2005 STi: 58,000 original miles
    Stock BBS's
    Goodridge steel braided brake lines
    Prodrive springs
    Cobb front & rear swaybars
    K&N Intake
    Helix downpipe
    SPT catback
    Cobb ap1 accessport
    Stage 2 tune by SS
    Debadged
    Will try and post pics
  32. C_wagginz
    purdy
  33. nik_05STi
    nik_05STi Member
    C_wagginz, were you actually able to view that link? I'm not sure i did that right
  34. C_wagginz
    Negative...the local zip file attachment will not display as an image. To use the IMG tags you need to have the files hosted somewhere online, such as flikr, picasa, photobucket, imgur, etc.
  35. superdoughboy4
    Go to www.photobucket.com, make a new account if you don't have one, and upload the image from your computer.
    Once the image is uploaded, go to your album, which there should be a link to it on the top of the page, and copy the IMG code from the picture. Highlight the picture with your mouse and it will show you 3 choices of links to choose from.
  36. G-WRX
    G-WRX Member
    Or.... You can use Flickr.com as a photo host for free.
  37. superdoughboy4
    ..? Photobucket is free.
  38. bixs
    Flickr is the shit though. <3 flickr
  39. nygiant
    nygiant Member
    17x9 Rota DPT Flat Black
    245/40 Sumitomo HRT-Z III
    Koni struts and progress springs
  40. superdoughboy4
    Wowww. Pretty sexy, green.
  41. G-WRX
    G-WRX Member
    Threw mine up, it's on the 2nd page... Let's see some more of our member's rides/specs.
  42. amonsta
    amonsta Member
    Well mine is a little wild but then again so am I!
  43. G-WRX
    G-WRX Member
    I honestly like that wheel color...
  44. Cool_____
    Stock as can be.
  45. b reel
    vert vette? and you call me old :rofl:
  46. Cool_____
    Yup. It's fun and it's also an auto. I don't deny I'm getting older. I enjoy it.
  47. superdoughboy4
    Oooooh sweet Corvette, Cool.
  48. Allpro Subaru
    Allpro Subaru Registered Vendor Supporting Member
  49. G-WRX
    G-WRX Member
    That white WRX is freaking sweet. What are the specs on those wheels?
  50. Cool_____
    I do love that white WRX. It's sweet.
