Silencer Delete?
Discussion in 'Introduce Yourself' started by jayj713, May 11, 2006.
  1. jayj713
    jayj713 Member
    I was just wondering how hard of a mod this will be to do. And also does it do a lot or will I just be able to hear my car more?
  2. pEd
    The only thing it's good for is noise. You'll hear more with it deleted.
    It is easy to do, just need to get into the passenger side fender well and pull it out from there.
  3. bluetwo
    bluetwo Active Member
    Yeah, but I think I would say fairly easy. Be prepared to really get your hands up into the fender to get that silencer out because there's this one bolt that is a beotch!
    Unless you have a lift. :eek:
  4. heathbar
    heathbar Member
    pretty easy, and the extra turbo noise is better music than most stuff on the radio :)
  5. clemsonscooby
    clemsonscooby Active Member
    If its not in the DIY on this site, go to ClubWRX or scoobymods. I know that those sites have it. Its not too bad, minus getting the snorkus out. You have to remove the fender lining after you jack the passenger side up and remove the wheel.
  6. moose
    FWIW, I didn't jack the car up or remove the wheel. :) It's a 5 minute job if you pop the right plastic pieces out.
  7. FTZ
    The Snorkus Removal is extremely easy. Like said above, there is one bolt that can be kinda tricky to get to, but overall this shoudl take anywhere between 30 minutes to an hour to do.
    Also, like said above, you really won't gain anything except for the sound of the Turbo.
  8. bigb996
    its a painless mod for your car that brings out that turbo spool for sure.
