slight wobbley feel?
Discussion in 'Modifications & DIY how-to' started by knhtrdr, Apr 16, 2007.
  1. knhtrdr
    knhtrdr Active Member
    Mostly in corners does that mean alignment, I know I need to get one since I have changed tires/rims just makin sure its not anything else.
  2. Weapon
    what springs are you running?
  3. mmtasty
    mmtasty Active Member
    Check your lug nuts!
    After that, were going to need a lot more info. Could be many things.
  4. calmnothing
    Lugnuts would be the first place to check. Afterthat i think it's the driver that's broken =P
  5. pEd
    I think you've just gotten too used to driving the big rigs.....
    I agree with everyone else though, check the lug nuts first, then post back.
  6. knhtrdr
    lol da suby feels like a go cart when I go from rig to car:ddirty:. I will check it out in da morning.
  7. clemsonscooby
    clemsonscooby Active Member
    If you have gone to a set of wider tires, its normal for the steering to be a little loose. The tires will grab a lot more grooves on the road. Its always good to get another alignment though.
  8. GTscoob
    It was rather windy last week, could that be the culprit? Check your tire pressures too, higher pressures tend to make the car darty feeling IMO.
  9. knhtrdr
    The culprit was tire pressure(too high,too low),wheel tighting(lugs) and front end was out of wack rears were fine GTE got me bendin corners like I supposed to in a suby. now to get the fenders rolled. and upgrade suspension.
