So Fla Autosports Time Attack STi
Discussion in 'Member Journals & Project Build Stories' started by SoFlaAutoSports, Mar 7, 2007.
  1. Hey guys! My name is Kenny From So Fla Autosports soon to be Flat4tecnica in Ft Lauderdale and Ive decided to start my journal thread. I have alot of pics that I will post later on when I have a minute and will make sure I keep you guys posted on updates. The pics i have now are old pics with my green/meth setup 450whp 450 trq tuned by SOG!
    As You know my goal was to build a street driven Time Attack machine. Here we go:
    Let me start with the mod list::)
    2005 Flat4Tecnica Time Attack STi
    Engine/Intake/Exhaust
    2.5L Fully forged block 9:1 Compression--Details hush hush so far undecided
    Custom Ported/Polished Heads and Cams-- Details hush hush ;p
    PE Timing Belt
    TGV’s Ported
    Port Matched Reverse Intake Manifold* until Flat4 Intake mani is done
    Element 4” Intake/velocity stack
    Koyo Radiator
    Samco Hoses
    Crucial Racing Thermostat
    Crucial Racing Radiator Cap
    HKS Circle Earth Grounding Kit
    Element Catch Can
    GFB Lightweight Pulley Kit
    1 step Colder Plugs
    Element Tuning Rotated GT 75 Turbocharger w 1.03 AR and .82 AR
    Thermal Coating on Exhaust side of Turbocharger
    Exhaust and compressor Sides ported
    Turbosmart 38mm Ultragate Wastegate
    Turbosmart “megasonic” Dual vent BOV
    Turbosmart eboost2
    Element Intercooler Piping with Thermal Coating
    Turboxs Front Mount Intercooler
    Hydra Nemesis ECU w/launch control
    Element Tuning Downpipe Thermal Coated
    Element Hydramist Meth Kit Possibly linked to Spec C 12 L Tank*
    Element Tuning Exhaust Manifold Thermal Coated
    Invidia Exhaust N1
    1600 cc RC Injectors with Custom rails/ext. fuel pumps/fuel pressure regulator/etc
    Cusco Engine and Transmission Mounts
    Custom Clutch –- details pending
    Lightweight Flywheel – details pending
    ACPT Carbon Driveshaft
    Defi Link Gauges Boost, EGT, Oil Pressure, Fuel Pressure
    ATI gauge pod
    Kartboy Short Shift Kit with Bushings
    Braille Lightweight Battery
    *Tuned By Scott at SOG * former setup
    NX Nitrous Fogger Kit 75 shot interfaced with Hydra
    ARC Titanium Engine Cover
    Tein Hood Dampners
    Prodrive Engine Oil Cap
    Prodrive Battery Tie Down
    Cusco Master Brake Cylinder Stopper
    STI Group N Pitch Stop Mount
    Interior
    Recaro Sportster Seats Blue
    Prodrive Steering Wheel Blue
    Prodrive Shift Knob Blue
    Prodrive Harness Blue
    Carbon Interior Trim**PENDING*
    Sparco Pedals
    Custom Roll Cage**PENDING**
    Exterior
    * Undecided body kit* looking at maybe widebody
    Do Luck Carbon Trunk
    Seibon Dry Carbon Vented Hood vented
    APR Carbon GT Wing
    APR Carbon Mirrors
    Custom Retro Fitted Projector STi Headlamps with Halos**PENDING**
    Custom Flat4 HID JDM Fog Lights on Greddy Front Bumper (Additional bumper)
    JDM Clear Sidemarkers
    JDM “I” STi Front Badge
    Prodrive Front lower Grill Kit for Greddy Bumper (Additional bumper)
    Prodrive Front Grill Mesh Kit
    Wheels/Tires
    BBS 17x7 Gold Stock STi wheels
    Prodrive 18x8.5 GC010g’s Gold
    Bridgestone RE70’s
    Toyo TR1
    Advan NEOVA
    JDM STi Valve Caps
    Prodrive wheel caps in carbon
    STI JDM carbon wheel caps
    STi JDM Lugnuts Blue
    Suspension/Bracing
    Tein Flex coilovers--Current Setup
    Cusco Front and Rear Swaybars--Current Setup
    Cusco Front and Rear Strut Braces--Current Setup
    Perrin Front and Rear Endlinks--Current Setup
    Performance Alignment from SOG
    Cusco H-Brace--Current Setup
    Carlab Brace- **Pending***
    New Coils-***Pending**
    RCE Lowering Camber Plates -**Pending***
    RCE Rear Pillowball Mounts - **Pending**
    Whiteline 27mm Adj. Front Sway - **Pending**
    Whiteline 24mm Adj. Rear Sway - **Pending**
    Whiteline Sport ALK- ***Pending**
    Performance Friction 2-piece front rotors- **Pending**
    Pagid Blue brake pads- ***Pending***
    Stainless Steel Brake Lines
    Quick Rack Steering Rack 11:1 ratio-**Pending**
    Suspension Bushings i.e.: tranny, cross member, etc.
    RCE Kook Brake Kit Ducting system--**Pending**
    Kartboy Exhaust Hangars
    Cusco Lateral Arms-**Pending**
    Cusco Control Arms-**Pending**
    I wanted to build a "drivers car". Purpose Built to be driven consistantly and how it was meant to be driven from day 1!
    I will have some more up to the minute detailed pics up shortly with shots of the build, the shop, etc.
  2. Alex
    Cant wait to do your headlamps ;)
  3. Me either!....ATL!!!!! lol should look very very nice! cant wait till may..
  4. miloman
    very bad ass
  5. JL889
    JL889 Pandastic!
    I like the outcast Evo muhahah
  6. miloman
    hahaha... i didnt even notice that
  7. This is what Im bringing in May..lol..maybe more...:ddirty:
  8. Yeah that was done on purpose lol..
  9. BelvnAWD
    I saw the same thing! Too funny...it looks sad...
  10. lol it should be!..death to evos! j/k
  11. pEd
    VERY nice there!!
    I can't even begin to imagine what gas mileage would be with a GT75 and 1600cc injectors....
    I'm sure it runs like a bat outta hell though.
  12. yeah gas is gonna be a killer but ill have a daily driver map on low boost that should make things a bit better lol.....well shes not running yet...the heads and cams are being done now and i should be able to bolt them on within a couple weeks and have the motor installed by the end of the month. Then ill bolt up the snail and accessories and break her in... Ill have pics up of the motor build up shortly. Im working on getting the cage done with some local guys down here.
    In the meantime I think Im going to work on the suspension and have siegel corner balance and align her.
    the end effect should have a 650 plus whp subie. she should make 600 rather easy but lets see what she does on race gas and spray...I really didnt build her for an all out power machine...just gave her the goods to do it lol. I;ll have different maps to play with and then have an "ultimate map" setup. so lets see what happens! ill keep u guys posted
    I should have her body stuff taken care of and painted in april just in time to check u guys out in GA!
  13. Cool_____
    Where you get that grill from and can I get it in black? I need protection for my FMIC and I wanna hide it a little.
  14. yeah thats a prodrive grill kit, i can get it for you, it doesnt come in black but ill spray it for u if u would like for no charge. Its the prodrive grill kit made for the WR1 STi...nice piece
  15. Cool_____
    It is nice. What's it made of? The only thing with spraying it black is that it tends to flake right off due to rock chips.
    PM the price.
    Oh btw that is a sick setup you have in the works man! Loving your car.
  16. Greg
    Greg Active Member
    Good Lord man!
  17. thanks bro i appreciate it..yeah its alot of blood, sweat, tears, and cash going into this project lol
    Hopefully we get to travel around the country and then take her to japan and tear up that part of the world...i have big plans, hopefully i get the support i need to take it that far
    thanks for the comments and ill keep u guys updated!
  18. ill get u a price with the details, and if need be since i have a bpdy shop i can this paint that works great on grills...ill get you details! thanks
  19. Weapon
    holy crap that sounds like a fun car. you planning on upgrading the stock rims?
  20. Alex
    He's got something up the sleeve, and I cant wait to see them mounted on the car :D
  21. lol me either..
  22. Greg
    Greg Active Member
    Wanna trade cars...?
    Yeah... didn't think so. :(
  23. wanted to show some updates on the build...
  24. Brian
    Brian Active Member
    yup, that's it. I'm drooling now.
  25. Greg
    Greg Active Member
    Good Lord son...
  26. heres some more pics so far..just some teaser pics..lots more goodies to come mwhahahahahaha lol
    thanks for the comments guys i appreciate it! more updates to come...
  27. Demo24
    Demo24 Member
    :drool: :eek3:
  28. pEd
    yep.... time to change my pants now.
    That's some nice chit you got going into that car.
  29. Greg
    Greg Active Member
    you suck man...
  30. lol lol u just wait till i get a hold of alex's and ur cars.....:naughty:
  31. Alex
    Hey, thanks for the picture of my seats ;)
  32. miloman
    i think i wet my pants
  33. AirMax95
    AirMax95 Active Member
    Wow.....you car maka louda sound whens a running I bet!
    Can't wait to see the finished product!
  34. Cool_____
    Yep my pants are wet......sigh
  35. my pants are wet everytime i sit back and look at her! lol
    Im working hard to build her by the time i need to have her up in atlanta for the meet and track time. I have ALOT to do on her and im deciding whether or not to put the bottle on her now or later on.
    A build of this size always has complications so I try to be as patient as I can.
    Im gonna make some pipes for the intake manifold today. Im deciding on a couple options on the intake manifiold...I want to make sure its the best for my application.
    The suspension/brake setup is on hold for now because i might get a hold of a 6 piston front 4 piston rear setup that ******** makes lol...hush hush sh*t.
    The build will be unique thats for sure...just a taste of what Im bringing to the community really.
  36. Greg
    Greg Active Member
    :sx: :ddirty:
  37. Cool_____
    Sweet....wanna build mine for me? For free? LOL
  38. Alex
    While you're at it, build me some brackets that make the hyperflow seat correctly.
  39. jonnyboy0150
    jonnyboy0150 Member
    Very nice ride! I bet that thing is pretty scary!
  40. oh it will my friends it will lol.......the countdown continues
  41. siegelracing
    Ooooh brake ducts.... Me likey.
  42. thank u sir!
    Ill be in Atl may 13-20 SS give me a shout to make sure we get tune/dyno time setup:naughty:
  43. Alex
    so the next package shipped out for you today didnt it?
  44. well i should have some updates for u guys this week or so. I should have some new pics also...im expecting some "special" goodies here so hopefully i get them in soon. Ive been sick so everythings been at a standstill for like 2 weeks or so.
    Trying really hard to have the car done by may but it might not be done in time...lets keep our fingers crossed...sucks doing all this by urslef sick lol
    Hey any of u guys wanna come down and help with the build?!!")
  45. pEd
    If I only could, I'd be there pronto.
    I want to see this thing in person...
  46. that would've been great! sh*t I wanna see this thing done lol!.....im still waiting on some parts to be shipped so thats also holding me back....she should turn out a beast...aiming for 650+whp 700 would be ideal..
  47. Greg
    Greg Active Member
    Good lord son...
  48. then when i get tired of that ill slap a gt40 or something on there lol....
  49. Alex
    just stay out of the hospital dude
  50. im trying...although they has like three nurses id so own there lol
