So I'm looking for a turbo....
Discussion in 'Modifications & DIY how-to' started by calmnothing, Jun 4, 2007.
  1. calmnothing
    So here are the plans...
    ej25 block
    9.2:1 pistons
    Forged rods n all that jazz
    SOHC heads
    Delta cams with a very spicy grind
    Now I just need a turbo. I'm looking for something twinscroll and will do 15psi-ish and not be out of its efficiency range at 7k rpms. So I want really good mid and top end. Am I asking for too much?
  2. slowwrx
    why not just do a dohc
  3. calmnothing
    Cause SOHC already comes on my car lol
    Plus my SOHC flows better than wrx DOHC
  4. calmnothing
  5. WJM
    I'm doing the same thing and I am going to start with an 18G.
  6. calmnothing
    I have my heart set on being different and being twinscroll =(
  7. WJM
    US WRX heads and cams suck.
    With cams...suck less....but still suck.
  8. WJM
    Twinscroll=t3h ghey.
  9. calmnothing
    Why teh ghey? Spools up faster quiets the exhaust because of no more subaru grumble
  10. WJM
    In theory....I was going to do TC....but after some serious research...too much $, time and effort spent for too small a gain. Stock single scroll header is best with the appropriate turbo for your needs.
  11. calmnothing
  12. WJM
    Full boost at 3800....no thanks.
  13. calmnothing
    I'll be running a higher comperssion....i'm sure it'll boost a bit quicker
  14. WJM
    if that spec C was a true spec C...EJ207...then the same turbo on your 2.5 should reach full boost at like 2800 rpm.
  15. calmnothing
    now that sounds yummy..a guy on Nabisco made like 350lbs/tq and had a pretty flat curve till 7k redline.
  16. slowwrx
    There aren't any flow numbers in the link you posted. Port size has virtually nothing to do with flow so I hope thats not where you guys are getting this info.
