SOG Warranty work
Discussion in 'Product & Service Reviews' started by rolling_trip, Jul 7, 2005.
  1. rolling_trip
    rolling_trip Active Member
    Before i got my Ecutek done i had a cel(302, misfire cyl 2) that kept coming up, and the engine idled very rough. After the tune the engine idle was much better, and figured that i need to change the plugs, because i got the error code a couple more times. While waiting for the plugs i never got the cel again and put off changing them. Fast forward 3-4 weeks later, while sitting at the drive thru last night i notice that my car again started idling rough, but no cel. well today while sitting in traffic i threw the old familar code, and called SOG. Scott seems to think it is a bad coil and should be replace under warranty, so i dropped it off tonight, thanks again to John for bringing me out to the country, since SOG could not find me a loaner, even though Scott tried several times. I will kep u guys posted on what comes out of it.
  2. miloman
    hope u get it back soon
  3. rolling_trip
    Just an update for you all. I picked it up the following Monday and notice that it was idling rough, unfortunly Scott was not there because of his trip to Tampa, so i decided that i would bring it back oneday. The very next day the CEL returned. They swapped the coil on #2 with #4's to see if i got a misfire in #4, i didnt. It was still CEL 302, misfire cyl 2.. I decided it was the spark plugs so i changed them last Monday, by the way only took an hr and a half. However still the same damn cel. As u might have guessed the car will be returning to SOG monday, but this time i will be getting a loaner. If anyone has any other ideas what might be causing this this is ur invitation to chime in.
  4. PapitoSTi
    PapitoSTi Member
    Sounds to me like a bad cylinder. But I might be wrong. And that a 05 STi, Hope its not a lemon. How many miles on it? Just thinking about you changing the spark plugs already.
  5. rolling_trip
    it has 23000 miles on it. i know thats a lot but still, its to the point now that i am scared to drive it, i just took a chance with the plugs i have some 1 step colder laying around. the plugs that came out didnt look that bad
  6. PapitoSTi
    PapitoSTi Member
    Your mods should not require a colder plug. Hopefully the cylinder is not cracked. Did they replace your coil wiring to that plug?
  7. ShaneSTI
    ShaneSTI Active Member
    damn chris...sorry to hear man. i hate it when my cars give me shi#. it'll get fixed dude...keep us posted.
  8. SkullWRX
    SkullWRX Member
    Chris, sorry to hear about that. good luck with the repairs and hopefully it's just something minor that'll take an hour or two to swap out.
    not trying to threadjack, but speaking of Scott's trip to Tampa... when is he supposed to get back?
  9. miloman
    he's back...
  10. siegelracing
    Papito, don't you think a bad cylinder is a heck of a conclusion to jump to??? What would make you think there was something wrong with a cylinder. Colder is always better on plugs as long as you aren't fouling them.
    I don't know of any '05's that are having cylinder problems, or anything else that would even approach a lemon...
    I appears it might have been either a coil-pack or an injector.
  11. rolling_trip
    I'll let u guys know tomorrow, i'm picking it up come hell or high water
  12. PapitoSTi
    PapitoSTi Member
    You never know, but I did also suggest a bad coil wiring. Hopefully that was not the problem. Did he find the problem? Changing to colder plugs in my opinion with those mods I won't do it but thats me.
